intake manifold gasket issue
Old May 5, 2013 | 02:37 PM
grindlecrew's Avatar
I have a 67 toronado with the 425, I did the top end on it, after re assembly it ran fine. then I noticed that the two rubber gaskets on the front and back of the block pushed out on each end. I took it apart and replaced the valley pan again, same thing happened. the rubber gaskets start working there way out as soon as the engine gets to operating temp. I am using gasket sealer and torqueing the manifold bolts as the manual states. Any ideas what could be causing this, I am thinking that maybe I need to replace the bolts, is it possible for the bolts to have stretched or something,
Old May 5, 2013 | 02:49 PM
coppercutlass's Avatar
Chevy budget Olds powered
Use a thick bead of silicone ditch the rubbers
Old May 5, 2013 | 03:10 PM
Yeah, this always happens with the rubber gaskets.
They are worse than useless.
... Made you buy two more intake sets than you would have, though, so I guess they served their purpose.
Old May 5, 2013 | 04:01 PM
Agree with the above.
I have read that the gasket material "The Right Stuff" works really well for that application. Apply a bead across the sealing area where the rubber seal would go instead of using the seal. I have also read that a bead of RTV has been used successfully, as has the rubber seal glued down with 3M Super Weatherstrip Adhesive (leave the top dry with no sealant).
Old May 6, 2013 | 05:12 PM
intake manifold issues
thanks for your help guys. I replaced the turkey tray today, threw out the rubber ends and am letting it sit till tomorrow night before I start it, and change the oil
aussiemobile
Feb 15, 2013 07:31 AM
coppercutlass
Jul 8, 2012 07:33 PM
Col Wickham
Mar 22, 2010 02:42 PM
stockwell
Feb 23, 2010 06:23 PM
Olds64
Jan 1, 2009 11:40 AM
