Intake manifold
Old Mar 18, 2010 | 04:59 PM
defiant1's Avatar
Intake manifold
On average, what can I expect to pay for a used (original) 4 BBL intake manifold for my SBO? I have a 2BBL set up now and am looking to upgrade to 4 BBL down the road, so I am gathering parts as I can.
Old Mar 18, 2010 | 05:50 PM
jensenracing77's Avatar
for the original one you are looking at between $450 and $1000. it will depend on how nice it is. i have seen some for $500 over the past year but were not in top shape.
Old Mar 18, 2010 | 05:57 PM
Try here: ros6872@hotmail.com
Old Mar 18, 2010 | 06:05 PM
defiant1's Avatar
Wow, I did not know they were that pricey. I thought since most people were going with the Edlebrock intakes due to lighter weight and better flow characteristics that the old cast iron intakes were not that desirable.
Thanks, I will send off a message shortly.
Old Mar 18, 2010 | 06:39 PM
Boldsmobile's Avatar
A standard iron factory manifold can be found for about $40. I am assume you are not looking for something rare or exotic.
Old Mar 18, 2010 | 06:52 PM
defiant1's Avatar
Correct, just a standard cast iron 4 barrel intake to throw on the 350. $40 seems reasonable.
Old Mar 18, 2010 | 07:00 PM
The_Jeremiah's Avatar
defiant1, i have a cast iron 4 barrel intake off of a 72 350 i think it was. i sandblasted the mating surfaces, ill sell it to ya for 40 bucks plus shipping. i have no idea how much shipping would be though lol
Old Mar 18, 2010 | 07:07 PM
defiant1's Avatar
PM sent
Old Mar 19, 2010 | 05:14 AM
I agree, $40 is a great deal. You might have to spend $40 for a rebuildable Q-jet as well.
Old Mar 19, 2010 | 05:29 AM
Destructor's Avatar
I'm looking to replace my Elel performer with a factory iron 4 barrel and Q jet then take a sledge hammer to the Edel.
Old Mar 19, 2010 | 09:41 AM
I wouldn't suggest that. Even if the carburetor is totally corroded and siezed up you should be able to get at least $10 for it (if not $40 or more) as a rebuildable core.
Old Mar 19, 2010 | 09:53 AM
Run to Rund's Avatar
All my Oldsmobiles have two barrel carbs. However, since we know Rochesters aren't so reliable I have several on each engine just to help ensure one will work at any given time.
Old Mar 19, 2010 | 09:58 AM
Destructor's Avatar
The Manifold I want to replace not the carburetor, but I can only use a Q jet on the iron intake. I have had excellent service from my Q jets and my present Edel carburetor.
Old Mar 19, 2010 | 10:03 AM
highlander's Avatar
what so bad about the manifold?
Old Mar 19, 2010 | 12:27 PM
defiant1's Avatar
Is there a certain model Q Jet 4 barrel that I should be looking for? Or is there just one 4 barrel version for the Olds with the iron intake?
Old Mar 19, 2010 | 03:10 PM
OOPS! i had the aluminum W-31 one on my mind when i answered the question. sorry, i was just looking for one of them on e bay before i seen your post.
Old Apr 11, 2010 | 05:51 PM
if your not worried about numbers, the newer the better, i spent some time working in a carburetor shop, and the tune ability of the newer q-jets is amazing compared to the old ones. if your really lucky you can find an 800 off of a chevy 454 around 1980. thats the most sought after q-jet i have seen aside from H.O. pontiac 455 q-jets. which is a carb in itself. either way do yourself a huge favor and find one with an electric choke. howd that intake work out for you?
Old Apr 11, 2010 | 06:06 PM
defiant1's Avatar
Hey, sorry I had not responded sooner. I'd received the intake a few days ago, but I was not home to check it out. It arrived in good condition, although I will be spending a good chunk of time trying to get those packing peanuts out of every nook and cranny they wedged themselves in.
A member on this site has got a q-jet off of a '77 350 he is thinking about selling. I am waiting to see what kind of choke setup that carb has.
Here is a newb question: Do all carbs have the same basic mounting plate? Meaning: can I take a 4 barrel q-jet off the 454 intake you mentioned and put it on an SBO 4 barrel intake?
And you are right that intake is one heavy SOB.
Old Apr 11, 2010 | 06:41 PM
Erinyes's Avatar
Yes, all quadrajets use the same base plate.
Old Apr 11, 2010 | 06:45 PM
defiant1's Avatar
Thank you
Old Apr 11, 2010 | 10:20 PM
yea man, lol i ate the shipping on that hardcore, but thats ok because i dont mind helping out another olds enthusiast. i hope that thing works out for you, a q jet, and if its not fast enough, a spacer plate, will make that thing run nicee.
Old Apr 12, 2010 | 01:44 AM
oldsonharmont's Avatar
When I wanted to upgrade the intake on my 455 donor motor to a 4bbl, I went with an original cast iron set up. I heard the aluminum ones were prone to cracking near the exhaust crossovers. I was lucky enough to find one locally and save the shipping.
shamusj
Dec 18, 2014 09:28 AM
svnt442
Jul 17, 2011 04:43 PM
jjatich
Jul 29, 2007 07:57 PM
SMOKEYMTNKUSTOMS
Oct 12, 2006 12:18 PM
magnusdog
Sep 2, 2006 10:01 PM
