Intake help
Old Aug 6, 2021 | 08:34 AM
Mikedeneen21's Avatar
Intake help
Can anyone tell me what these three are called ? I’m trying to find them. I took my car to a mechanic that completely fucked everything up.
Old Aug 6, 2021 | 09:30 AM
acavagnaro's Avatar
66 was referred to as a ported vacuum switch. Available aftermarket but originals are hard to come by. 63 and 65 look like oil pressure and coolant temperature sending units.
The ported vacuum switch was installed in the intake manifold in the front right corner (at least on 69's) and plumbed with vacuum lines to multiple locations. Should have at least 3 'positions' or line locations on the body. The oil pressure unit should be in the bulkhead just behind the water pump. Coolant temp sensor should also be located in the intake near the thermostat housing. Both 63 and 65 would be electrical connections to the engine harness. A different oil pressure sending unit was used for the Rallye Pak option but that's not what's shown in your diagram.
Old Aug 6, 2021 | 09:38 AM
b
Okay because this is how he hooked it up so far.
Old Aug 6, 2021 | 11:21 AM
BillK's Avatar
Mike,
What year car and what engine ? I might be able to get you a vacuum diagram.
Old Aug 6, 2021 | 11:47 AM
Originally Posted by BillK
Mike,
1977 olds 350 in a 1980 cutlass
Old Aug 6, 2021 | 12:54 PM
BillK's Avatar
Mike,
I am pretty sure 1980 would have had an electronic Quadrajet on it. I can tell from your picture which carb you have ? Is it from the original 350 or the 1980. I also cant tell if you have a vacuum advance distributor or the electronic one from 1980. All of that is going to matter. If you have all of the 1980 parts on it you should be able to use the 1980 vacuum diagram.
Old Aug 6, 2021 | 12:58 PM
Mike,
its all from 1977.
Old Aug 6, 2021 | 04:13 PM
Why don't you start by telling us year, model, engine, and options. That graphic covers all Olds motors from 1964-1981, and frankly, a diagram from a vendor like Chicago Muscle Car Parts is NOT a factory diagram. Your car may or may not use those items, depending on year and options.
Old Aug 6, 2021 | 04:14 PM
Mike,
Actually not, Bill. Olds never used the CCC system on a 350. Only on the 307 and 260 motors. 1980 was the last year for the 350.
Old Aug 6, 2021 | 04:17 PM
OK, so the next question is, what are you trying to do? Are you tying to put together a totally smog-compliant setup for a state like Calif? Or are you just trying to get this swap running?
Old Aug 6, 2021 | 04:18 PM
This is the vacuum diagram for a 1980 Cutlass with Olds 307 motor. The 350 would be similar that year. This was not a CCC 350.
Old Aug 6, 2021 | 04:22 PM
I’m just trying to get it running, and truly to figure out what goes where because the guy that was working on it told me i needed 3000$ in parts just to get it to fire up.
Old Aug 6, 2021 | 04:24 PM
And just for reference, here's a 1977 350 diagram
Find a new "guy"
Old Aug 6, 2021 | 04:27 PM
You don't need any of that stuff just to get it running. The emissions equipment won't be connected, but the engine will run. The fact that the clown working on the car can't even figure out how the heater hoses should be connected suggests that you should take that car and run, don't walk, away. Sorry, but that is completely f'd up.
Old Aug 6, 2021 | 04:28 PM
BillK's Avatar
Joe,
Thanks. I wasnt sure so I went into one of my parts stores online catalog and looked at a 1980 Cutlass and they actually showed a Throttle Position Sensor so I assumed
Old Aug 6, 2021 | 04:34 PM
I don’t know a whole bunch about motar work but i knew when i saw that i knew it wasn’t right.
w30442
Jun 5, 2023 01:17 PM
380 Racer
Sep 29, 2022 07:38 AM
72 Post
Jul 21, 2021 06:07 PM
1966g10
Nov 18, 2013 10:35 AM
southcarolina803
Jul 2, 2008 07:14 AM
