How do you remove the oil slinger & timing gear?
Old Apr 21, 2024 | 12:34 PM
James J's Avatar
Today I have a new front cover, gaskets, timing gear & chain set. I tried to take the oil slinger & timing gear off of the crank shaft with a 3 jaw puller, but there is not enough clearance to get the jaw around the timing gear before they hit the block behind it. The service manual called for a tool part # BT-6610 or J-25287 is there anyway to get these off without the special Olds tool & how do I get them back on? It is a 1984 307 which has a larger gearset and chain compared with older V8's 83 and Back. Thanks Jackson
Old Apr 21, 2024 | 03:10 PM
2blu442's Avatar
I have never worked on a 307, but the 330-455 I've had apart the slinger slides off by hand. Then I've unbolted the gear from the cam, gently pried on each side and 3:00 and 9:00 until it became loose. Then I wiggled it back and forth until I could pull it off by hand. If the 307 is different someone with experience on those will have to speak up. John
Old Apr 21, 2024 | 05:04 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
As said, the slinger should slide right off. The crank gear does need a puller, get a smaller two or three jaw puller. I had no issues or anything different than removing gears on a 307 vs any other Olds V8.
Old Apr 22, 2024 | 06:15 AM
I've done several 307 timing chains. Yes the slinger comes off. There is actually a Kent-Moore tool for the crank gear.
Old Apr 22, 2024 | 05:44 PM
BillK's Avatar
Just want to add that if there is a lot of miles on it the slinger will get glued on pretty good. Just pry on it a little or tap it with a small hammer and it should come off.
A lot of guys will frown on this but if you are replacing the small gear and you have a small sharp cold chisel, put the chisel between two teeth and smack it pretty good with a hammer and most of the time it will crack the factory gear and then you can pull it off almost by hand.
Dogge
Mar 11, 2020 10:43 AM
Thomas Diefel
Non-Olds Engines
Aug 28, 2018 08:55 PM
73aussie455
Apr 18, 2014 02:41 PM
ChefDeadpool
Mar 30, 2011 09:16 PM
rallye455
Jan 1, 2011 07:10 PM
