High frequency noise
Old August 18th, 2018, 09:10 AM
Levellord's Avatar
Hello Gents,
last year I swapped my engine when the old one blew up.
When the new engine is running, approx. a few seconds after its running I have a very high frequent tone, you here it while driving. It doesnt sound mechanical, it sounds like the sort of cheap trafos. It is totally disturbingly.
All aggregates have been overtaken from my old engine.
What I know: it is not rpm related. It is always the same.
It is not from the aggregates. I loosen the belt to check for a few seconds, still there. It is not from vacuum, all carb exits are plugged. I cant locate it proper, but when driving it seems to come from the passenger side.
My guess was first the ignition coil, but everybody here tells me that a coil cant do this kind of noise.
So, I have no more ideas and hope that someone had a similar problem and the solution....:-)
thanks, marc
Levellord is offline
Old August 20th, 2018, 05:05 AM
Marc, you mentioned that you loosen the belt and the noise is still there. Did you loosen all the belts? The engine can run for a short time without the water pump circulating coolant.
Also, try to id the noise with a mechanic's stethescope.
Olds64 is offline
Old August 21st, 2018, 12:11 AM
Levellord's Avatar
Yep. I loosened (sounds strange?) all belts. Noise still there.
Old August 21st, 2018, 02:38 AM
shiftbyear's Avatar
Does the car have to be moving to get the sound? Maybe find a long stretch of traffic free road and coast with the engine on and off with the trans in neutral. Could be wind related. Just guessing, good luck.
shiftbyear is offline
My2nd 69 442
June 18th, 2018 06:15 PM
young olds
June 1st, 2015 10:04 AM
Betsyd68
July 26th, 2014 08:52 PM
72CUTTY
March 23rd, 2014 10:52 PM
WasteOfMind00
April 12th, 2007 06:38 AM
Quick Reply: High frequency noise
