HEI Ignition
Old May 2, 2016 | 03:56 PM
WackyTacky's Avatar
HEI Ignition
Looking for a clearance question to be answered, I was thinking of going with the large HEI ignition on a 350 Oldsmobile Cutlass 1968 convertible, is there enough clearance between the distributor and firewall? after the engine is installed can I remove the distributor or is it to tight?
Old May 2, 2016 | 04:28 PM
redoldsman's Avatar
Proud Viet Nam Veteran
The air cleaner is a bigger problem than the firewall. Of course you may be using an aftermarket air cleaner. Be sure you put it in so the vacuum advance doesn't hit the firewall. It is a tight fit but it will work.
Old May 2, 2016 | 04:32 PM
X2 on what Red said. I would stab the distributor after the engine is installed to prevent damage to it.
Old May 2, 2016 | 04:55 PM
WackyTacky's Avatar
Thanks, I have to admit, this forum is like Gear Heads on Steroids, I love it.
djchunter
Mar 17, 2016 03:57 PM
joepenoso
Jun 4, 2014 01:56 PM
yeahbuddy
Sep 13, 2011 01:19 PM
oldscruiser
Feb 15, 2011 12:44 AM
Thomas Simcich
Jul 23, 2010 12:53 PM
