Which Head Gasket
Old May 24, 2015 | 01:22 PM
truckerlary's Avatar
Which Head Gasket
I think I saw a forum question about which head gasket to use on a 350 olds to give the best compression. I think they called it a fel-pro blue gasket. Does anyone know what the part no. of the best head gasket to use to get the best compression. Thanks Larry
Old May 25, 2015 | 07:01 AM
The thinner the installed thickness of the gasket, the higher the CR. The FelPro blue gaskets are probably the most reliable from a sealing standpoint, but they are also the thickest installed gaskets and thus the LOWEST CR. Of course, we're talking about less than half a point of CR variation from thickest to thinnest. It's unlikely you'll feel any difference in a street-driven car. If this is an otherwise stock or near-stock engine, just used the FelPros.
Old May 25, 2015 | 09:51 AM
M-14's Avatar
You could also have a little more machined off the heads.
JPMDaddy
Jan 14, 2019 08:41 PM
rustycragars
Dec 25, 2016 06:06 PM
dallasite21
Jun 20, 2010 05:37 AM
thomaswatk
Mar 22, 2007 01:31 PM
Sixoh
Aug 8, 2006 05:11 AM
