fuel pump
Old Jun 23, 2010 | 03:15 PM
mryoung4815's Avatar
fuel pump
how can you find out if your fuel pump is not working...not getting any gas to carb but i have a full tank
Old Jun 23, 2010 | 03:43 PM
Blk71SX's Avatar
equipment needed; 1" & 5/8" wrench, 1' of 7/16" rubber fuel hose, catch container. a 16 oz water bottle works good.
remove steel fuel line at carb and slip rubber hose over the flair, other end in the bottle. prop up the bottle or have someone hold it to catch the gas as the entine is cranked. this is for unaltered factory set up
no fuel = bad pump, clogged fuel line, or hole in fuel line allowing pump to suck air. the strainer in fuel tank could be clogged.
Old Jun 23, 2010 | 05:35 PM
Joffroi's Avatar
Runner
Had a similar issue with my SX. Car would cut out after a little driving. Worst case you are in my boat, fuel tank needs to be "resealed". Best case, change some fuel filters and or pump
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
mefirst72
Feb 10, 2013 06:37 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
sshriber
Mar 22, 2010 06:16 PM
