fuel line / filters
Old Jan 26, 2012 | 06:37 PM
coppercutlass's Avatar
Chevy budget Olds powered
fuel line / filters
Ok i just finally got the finisheing touches on my current engine . I installed a new converter , new holley 650 dp, and re did some wiring and touched up the firewall. My question is do i need a filter between the carb and fuel pump. I run one of those big inline canister filters running from the fuel cell. I also left in the filters in the holley that go on the inlets . My main issue is space . I put my regulator in line to the dual feed line to save fuel line and hose but now all i have is 6 inches from the pump to the regulator. Will another filter inline right before the pump work as well ?
Old Jan 26, 2012 | 08:59 PM
yankees's Avatar
Coppercutlass you don't need another filter between the pump and carb, since you already have a canister filter before the pump. Also, get rid of the bowl inlet filters as they are not needed. Any reputable carb builder doesn't install them either.
What did you do with your other converter and what size was it?
Old Jan 27, 2012 | 04:54 AM
That converter is goin in my dad's car . I'm going to use the fuel inlet filters I see them as no harm. If I see a lack of fuel. I'll remove them
Del70
Dec 7, 2025 02:13 AM
RAMBOW
Jul 30, 2013 03:40 PM
starfire
Mar 17, 2013 06:58 PM
davepnola
Dec 2, 2010 09:00 PM
68conv455
May 20, 2008 02:03 PM
