Which Factory Intake to Use?
Old Oct 15, 2021 | 08:21 AM
70RocketSteve's Avatar
Hello,
I have a 1970 350 engine that had a 2bbl factory intake on it (I have). I am going to get a complete mild rebuild and was wondering if it would be beneficial to install the 330 4bbl non egr intake (I have). The engine is in a 1979 Cutlass Brougham which currently has a 4bbl factory erg intake on it from the 80's. Thanks for the advice in advance.
Steve
Old Oct 15, 2021 | 10:13 AM
You'll definitely be happier with the 4bbl carb.
Old Oct 15, 2021 | 12:45 PM
Do you know the year and CID of that engine "from the 80's"? Some of the 80s intake manifolds are good, and some are not.
Old Oct 15, 2021 | 12:58 PM
I don't know what the 80's manifold is. I will check and advise.
Old Oct 15, 2021 | 12:59 PM
The 66-67 330 4bbl or the 80's 4bbl?
Old Oct 15, 2021 | 01:36 PM
That may depend upon which 80s intake manifold you have. But in reality, any 4bbl should be better than the 2bbl.
Old Oct 15, 2021 | 06:18 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Is the 330 a spreadbore intake? That looks the the usual #17 iron early 307 intake, as good as any iron intake.
Old Oct 15, 2021 | 06:55 PM
​​​​​​Here is a pic of the 330. #390327. Better performance than the "early 307"?,???
Old Oct 16, 2021 | 06:45 AM
The difference will be minimal plus you have to convert to electric choke, your call.
Old Oct 17, 2021 | 05:37 AM
I'm going to stick with the one that is on it. Upon further inspection, it is a #16 off a 403 77-79! I put that intake on back when I was 19 years old. (51 now).
Old Oct 17, 2021 | 05:39 AM
It's actually a #16 from a 403 77-79. I'll stick with that one!
Old Oct 17, 2021 | 07:21 AM
Agreed, the #16 should be fine.
Old Oct 18, 2021 | 12:37 PM
cjsdad's Avatar
I did something similar on my 67 330 engine. I took off the TwoJet carb and manifold and installed an EGR equipped Q-Jet manifold. I used the EGR manifold because it was free from the wrecking yard! I installed the EGR Valve cover plate like yours but I also tapped and installed pipe plugs in the holes under the carb inside the plenum. I dunno if it made a difference or not, but it did give me a sense of accomplishment. I also ran it through an Evap-O-Rust bath after the pics were taken.
Old Oct 18, 2021 | 03:58 PM
Sounds like a good idea! I can't see where it would hurt. Thanks for the input.
Steve
380 Racer
Sep 29, 2022 07:38 AM
Wildcard
Dec 26, 2012 07:48 AM
oakwith
Jul 18, 2012 05:50 PM
dwsshay
Apr 20, 2010 02:57 PM
southcarolina803
Jul 2, 2008 07:14 AM
