350 intake
Old Apr 19, 2010 | 09:07 PM
dwsshay's Avatar
70 hulk
350 intake
can anyone tell me if a 1974 intake fits on a 1970 engine, thanks
Old Apr 19, 2010 | 09:31 PM
stan 65 cutlass's Avatar
should fit no problem, except for the choke may be a different setup
Old Apr 19, 2010 | 10:05 PM
svnt442's Avatar
They were both hot air chokes. The only difference will be the 74 has an EGR where the 70 does not.
Old Apr 19, 2010 | 10:19 PM
ahhhh, i have a 69 with choke coil inside manifold, 76 has heat risers under choke side of carb they must have changed in 70. what is the egr? and do you need it? exhaust gas recovery?
Old Apr 19, 2010 | 11:48 PM
svnt442's Avatar
Technically it's Exhaust Gas Recirculation. It sends a bit of exhaust gasses back into the intake to be re-burned.
Old Apr 20, 2010 | 02:57 PM
Warhead's Avatar
Technically, it goes back into the combustion process to lessen combustion temperatures, which lessens exhaust emissions.
Jim
arodenhiser
Nov 30, 2012 06:25 AM
Nickyloves442s
Oct 24, 2012 04:55 PM
svnt442
Jul 17, 2011 04:43 PM
dharlett
Sep 23, 2009 03:30 PM
71cuttyS
Oct 31, 2007 04:58 PM
