Engine Removal
Old Jul 12, 2010 | 12:27 PM
frasco's Avatar
1970 Cutlass Convertible
Engine Removal
Which bolts do I attach the engine hoist to in order to remove the engine from a 1970 Cutlass
--Scott
Old Jul 12, 2010 | 12:52 PM
dan2286's Avatar
I usually use the bolt holes on the heads all the accessory brackets bolt to. Just find some grade 8 bolts with the correct thread size.
Old Jul 12, 2010 | 12:59 PM
frasco's Avatar
On the heads or the intake manifold?
--Scott
Old Jul 12, 2010 | 01:03 PM
dan2286's Avatar
--Scott
Heads. There is 3 bolt holes on the front and back of each head you can use.
Old Jul 12, 2010 | 01:06 PM
frasco's Avatar
My hoist has two attachment points, is that enough? I guess one on the front and one on the back?
--Scott
Old Jul 12, 2010 | 01:07 PM
mauls's Avatar
Green Horn
I used the bolts on the intake manifold on mine
Old Jul 12, 2010 | 05:15 PM
442Harv's Avatar
I like to use a carb plate. Does not cost much, and you can place it in different holes, so like if you take the tran with it, same time, put it in the front hole, and as it comes out it tilts down in the back, and makes it easy to come out. You do need a helper to do it this way, but works great. Should have a helper, no matter how you do it anyway.
Old Jul 12, 2010 | 05:45 PM
Bluevista's Avatar
Registered
I used the holes in the front and back of the heads too, a couple of links bolted on each one to be safe and on all four corners.
An engine tilter is a fairly inexpensive tool and makes things a whole lot easier.
You can borrow mine if you're lucky and fortunate enough to be close to beauteous Cleveland, Ohio.
A guy borrowed my cherry picker and then he went and croaked and I never saw it again, so only if you're healthy.
I'm glad he didn't borrow my engine tilter too.
Kaline
Apr 18, 2022 03:35 PM
805cut
May 3, 2012 08:11 PM
Red Delta
Jul 21, 2009 05:47 AM
sklbndt
Feb 24, 2009 03:20 PM
elmo
Sep 23, 2007 02:49 PM
