Engine Knocking
Engine Knocking
My '73 Delta 88 350 engine knocks when I accelerate heavily and especially uphill. I have the timing adjusted correctly, but it still does it. I have heard that this may be because I us regular 87 unleaded gas. I have heard that these older engines require premium all the time because of compression issues or something. Is this true, because I really don't feel like paying for premium at the pump.
chris
chris
chris
chris
The harmonic balancer is on the crank pulley. It is where your timing mark is located. You can double check your timing mark by kicking your engine over to TDC on the # 1 cylinder (hold your finger over the spark plug hole and crank the engine with the coil wire off). Then look for your timing mark next to your advance indicators.
TennesseeDelta
Mar 27, 2007 02:01 PM
