Dip Stick Troubles
Old Jul 15, 2010 | 08:47 AM
74 Omega's Avatar
Dip Stick Troubles
OK, so this is a stupid question, but I am at my wits end.
After putting this back together, I am having problems with the dip stick. It is too loose. Last year or so, after installing headers I removed the OEM dip stick and installed a chrome Summit unit. It seemed to fit fine. This winter I removed the engine did a few upgrades. After reinstalling the engine, I did the headers; go to put the dip stick in and it just slides right in, no resistance.
I figure I must have "stretched" the bums out when I removed it, so I order two more from Summit, a Summit one and a Specter one, (BTW they are exactly the same just one was $11.95 the other $12.95) both of them do the same thing?? What am I missing?
Just pulling out the dip stick pulls out the tube, it will not stay put.
(1974 - 350 block)
As always, Thanks for the help....
Old Jul 16, 2010 | 02:29 AM
Yellowstatue's Avatar
What I did with headers installed was put a metal tube clamp around the tube and use the closest header bolt to secure the tube and voila... adjust the hole size in the clamp to fit the header bolt...
Old Jul 16, 2010 | 04:16 AM
Blk71SX's Avatar
Loctite green
bulldog
Jun 8, 2010 06:37 PM
fmay50
Dec 17, 2009 10:45 PM
hamm36
Jul 15, 2008 10:23 AM
Olds luvr
Apr 22, 2008 05:20 PM
leslie
Ninety-Eight
Sep 17, 2007 06:17 PM
