carb spitting
carb spitting
When i first picked up my olds, it had a 260 in it. i'm trying to get it running until I can finish the build on my new motor.
The original carb was in bad shape, so I bought a re-built carb, it's a Rochester dual jet 2 barrel.
Same problem as the old carb, It will start and idle sometimes. Other times when you crank it, it will make a "spitting" sound and spit a mist of fuel directly vertical out of the carb.
Is it something wrong with the timing?
Also, there are several vacuum lines not attached, I attached all I could that came with the car, but there are at least two vacuum connections not attached on the carb, and the crank case breather isn't attached either.
If the car spits a fuel vapor directly up and then dies you may have a timing issue not a carburetor problem. Is the engine fully tune up? If the open nipples are 'sucking' air when the car is running then they are creating a vacuum leak and you need to put a cap on them, this could cause your first problem too.
There were no hoses attached to the factory intake, they were probably lost or misplaced with the previous owner. I will check to see if those lines are sucking in air.
Thanks for the reply
Turn your balancer to zero, and your #1 cylinder to top dead center. You will have to pull the #1 spark plug to see the piston.
Then pull the cap, and let us know what cylinder the rotor is pointing to.
FrankElTanke
April 12th, 2013 07:15 AM
Dool Cat
September 28th, 2012 11:13 AM
