carb spitting
Old Jun 24, 2010 | 06:47 PM
mauls's Avatar
Green Horn
carb spitting
When i first picked up my olds, it had a 260 in it. i'm trying to get it running until I can finish the build on my new motor.
The original carb was in bad shape, so I bought a re-built carb, it's a Rochester dual jet 2 barrel.
Same problem as the old carb, It will start and idle sometimes. Other times when you crank it, it will make a "spitting" sound and spit a mist of fuel directly vertical out of the carb.
Is it something wrong with the timing?
Old Jun 25, 2010 | 08:07 AM
mauls's Avatar
Green Horn
Also, there are several vacuum lines not attached, I attached all I could that came with the car, but there are at least two vacuum connections not attached on the carb, and the crank case breather isn't attached either.
Old Jun 25, 2010 | 08:45 AM
Oldsguy's Avatar
Past Administrator
If the car spits a fuel vapor directly up and then dies you may have a timing issue not a carburetor problem. Is the engine fully tune up? If the open nipples are 'sucking' air when the car is running then they are creating a vacuum leak and you need to put a cap on them, this could cause your first problem too.
Old Jun 25, 2010 | 09:02 AM
mauls's Avatar
Green Horn
The engine has been sitting for quite some time. I changed the oil, spark plugs, wires, filters, and re-built carb.
There were no hoses attached to the factory intake, they were probably lost or misplaced with the previous owner. I will check to see if those lines are sucking in air.
Thanks for the reply
Old Jun 25, 2010 | 09:14 AM
Oldsguy's Avatar
Past Administrator
I just hope my idea helps. I could be way off base though. Let us know what you find out.
Old Jun 25, 2010 | 11:24 AM
mauls's Avatar
Green Horn
I think you're right on. It's gotta be a timing issue.
I tried to rotate the distributor, but I couldn't get it to budge, there's gotta be a set screw on there or something.
Old Jun 25, 2010 | 06:42 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Turn your balancer to zero, and your #1 cylinder to top dead center. You will have to pull the #1 spark plug to see the piston.
Then pull the cap, and let us know what cylinder the rotor is pointing to.
Old Jun 30, 2010 | 10:47 PM
BILL DEMMER's Avatar
Just the facts...
sorry, i have to ask the obvious...
did you loosen the distributor hold down clamp?
bill
FrankElTanke
Apr 12, 2013 07:15 AM
RandyS
Oct 4, 2012 12:36 PM
Dool Cat
Sep 28, 2012 11:13 AM
85LS
32
Aug 17, 2009 08:19 PM
f-85
Dec 23, 2008 05:05 PM
