Cam
Old November 5th, 2010, 07:01 PM
BigTrav's Avatar
Cam
Edelbrock Performer RPM intake manifold
Edelbrock Performer Carburetor 600CFM 4 barrel
LUNATI OLDSMOBILE 262/268 VOODOO CAM & LIFTERS #60802LK
(http://cgi.ebay.com/ebaymotors/ws/eB...#ht_2554wt_947)
Does the cam fit with the performer rpm and carb for a 350 Rocket?
BigTrav is offline
Old November 6th, 2010, 11:52 AM
cutlassefi's Avatar
Yes but imo the carb is too small. Stock heads?
cutlassefi is offline
Old November 6th, 2010, 12:07 PM
BigTrav's Avatar
How large of a carb would you recommend? Yes the heads are still stock, I was told they were perfect for the car and should keep those. I'm really not too big on the mechanics of the car and this is the first one I'm having rebuilt. I have another question for you. Besides the obvious manifold, carb, and cam, what other things need to be replaced for sure when rebuilding an engine? I'm seeing on some sites they are recommending timing chains, lifters, springs, and other things. I'm just wondering what definitely needs to be replaced...no issues on buying the parts I just don't want to waste money that could be spent on other things in the car.
BigTrav is offline
Old November 6th, 2010, 01:09 PM
cutlassefi's Avatar
Need more info but in a nutshell, Cam, lifters, timing chain and gears, rings, bearings and gaskets. The other stuff depends on your budget and ulitimate goals.
Old November 6th, 2010, 01:21 PM
BigTrav's Avatar
Well, originally I wanted alot of power but now I'm just trying to have a dependable engine with a little kick when I step on it and a decent exhaust. The only things I have thus far are the three pieces mentioned earlier(carb,cam,mani). I'm currently just trying to purchase the parts for a decent setup so I can have the engine rebuilt on about a 3k budget.
BigTrav is offline
Old November 6th, 2010, 04:47 PM
cutlassefi's Avatar
Gear, compression ratio? Tranny?
Old November 6th, 2010, 05:01 PM
BigTrav's Avatar
That's where I need the help at?? The transmission is still the original transmission that came in it. I was planning on keeping it the same. Some have told me to go with 3:23 gears, others have said 3:73 gears. As far as compression ratio I have no idea @ all. As you can see I'm not a genius at all when it comes to the rebuilding of engines...
BigTrav is offline
Old November 6th, 2010, 07:36 PM
cutlassefi's Avatar
You have to decide what you want. But imo go with a 3.23 or 3.42, 9.0-9.5:1 compression. That'll give you the luxury of having a few more choices for a cam, and still be very driveable.
grmchne78
June 25th, 2015 06:23 PM
Oldsmaniac
June 20th, 2014 05:44 AM
Uncle Hulka
March 12th, 2014 03:41 PM
72RocketPower
August 11th, 2005 04:51 AM
Rocketman
November 22nd, 2004 01:59 PM
Quick Reply: Cam
