A/C delete squeal from hell
Old Feb 14, 2013 | 08:47 AM
Johnny Cage's Avatar
Ive been searching online. and it seems when i deleted my smog and a/c. It is the reason that i get a ridiculous noise of screeching. I replaced water pump. and have new belts. still squeaks. will get hot and break
How do I stop this.
Im reading by getting a pulley attachment(need part number) and adding a belt to help.
or relocating my alternator.
Thank you for any help.
Old Feb 14, 2013 | 09:58 AM
I am seeing that I can buy a 2 groove pulley for the power steering. If i do this. does anyone know what belt number i will need?
could be a dumb question, but couldnt i run a belt from the groove closest to the motor around the water pump? would this resolve the squeak
Old Feb 14, 2013 | 10:27 AM
Are you certain that you tightened your belts properly after removing those components?
Old Feb 14, 2013 | 10:49 AM
tightened the ps by prying against, and tightin the screw. then did alt. tried a variety of tensions.
what ive scene from others, is they are having the same problem after the a/c smog delete. That is when the squeaking started. then it would go away. now it is here to stay
Im seeing that i can get the dual pulley PS pulley, but i dont know what belt to get for the alt to run around that.
Old Feb 14, 2013 | 11:21 AM
I will attempt to re adjust the PS.
There is one bolt threw the pulley.
I have one screw left over, and ive been racking my brian tryin to find out where the hell it goes. has to be on the PS somewhere
Old Feb 14, 2013 | 11:36 AM
Make sure that you understand that there are three fasteners on the P/S pump, and where to pry, as described by Joe P here.
Old Feb 14, 2013 | 11:46 AM
Apparently you didn't search HERE...
https://classicoldsmobile.com/forums...lt-squeal.html
https://classicoldsmobile.com/forums...-slipping.html
https://classicoldsmobile.com/forums...elt-loose.html
https://classicoldsmobile.com/forums...t-removed.html
At the risk of yet again repeating myself, I have personally run my 307s without the A/C and A.I.R. belt in place with NO, NADA, ZILCH squealing. Be sure you are properly adjusting the tension in the PS pump belt. See the photos in the threads I've linked to.
Old Feb 14, 2013 | 11:51 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Belt squeal is related to these things:
1. Glazed belts & pulleys
2. One of the components is seized up or has higher than normal rotational force. So it
could be causing belt slip or you could be hearing bearing squeal?
3. Loose belt. ( improper deflection)
4. Pulley misalignment.
5. A counter rotation component put in the wrong application
6. Wrong belt "shiv" dimension. Width & depth not belt length unless it’s too long to
tighten to proper deflection spec.
7. Pulley mismatch different shiv angle and depth. Less likely unless you really have a
Hodge-podge of parts.
8. The pitch and angle you’re trying to overcome with the missing pump could be a
problem too. May have to install an idler. Usually on the newer cars that’s the solution
if a customer doesn't want to spend the money on say a new A/C pump we bypass it
with a idler if possible.
Several ways to obtain an unknown belt size. One method is to use string or twine and wrap it where the belt should live. Or cut down a longer belt. Take that string dimension or belt to an auto house that has a good selection and grab two or three within that range. They generally come in 1-2" increments. Try them all until you find one that will give you mid-scale resolution (middle of the adjustment travel). Stay clear of the cogged style belts in favor of the solid.
My bet is #2 or # 4. But step one is to check for proper tension deflection then move to the more complicated problems.
Last edited by droldsmorland; Feb 14, 2013 at 11:52 AM. Reason: Joe typed to fast or I typed to slow prob the latter
Old Feb 14, 2013 | 01:17 PM
CRUZN 66's Avatar
Olds Fever
I haven't done it myself, but for what it's worth, a few people I know have solved that problem by relocating the alternator to the passenger side of the engine. Just install a set of passenger side brackets for the alternator, they aren't that difficult to find........... This should rebalance the tension on the crank and water pump pullies since you will now be pulling from both side of the engine just as if the A/C compressor was still mounted....
Old Feb 14, 2013 | 01:34 PM
Thank you for all of the links. I have a couple of those saved. I have been researching all day.
I am going to try to adjust the PS in the manner described.
I know where the "threw" bolt is.
then there is the bracket mount down underneath. what area is the second front bolt positioned? I believe that is where my mystery left over bolt is going to go.
how many "turns" slack should be on the PS belt?, and the alt while i'm here
Thank you very much
Old Feb 14, 2013 | 02:11 PM
In the photo I posted in the other threads, the second bolt is directly below the pump snout and is not visible in that photo. If that bolt is not currently installed, it's no wonder the belt is squealing.
I don't know what you mean by "turns". I get the PS belt as tight as I can with the screwdriver as shown in the photo. I guarantee it will loosen a little once you get the fasteners tight. Also be aware that brand new belts will often stretch a little and will need to be readjusted after a while.
Old Feb 18, 2013 | 09:17 AM
Almost had the PS adjusted. the kid that was helping me busted the top mount part of that holds the alternator. it just snaped in half, cheap aluminum braket.
Question is, What is that top bracket called? Im trying to find a replacement to mount up the alternator in the stock location
any help is apricated. advanced and napa could not get
i will try junk yards if i have to, but living in CT, they dont have many olds sitting left, that im aware of
Old Feb 18, 2013 | 09:31 AM
If you're talking about the alternator bracket that bolts to the front of the driver's side head, the techincal term is, ah, alternator bracket. You won't find one for sale from an auto parts store, because they are not a normal wear item. I suggest you not let the incredible Hulk work on your car anymore.
Any Olds 307-powered GM is a donor. Look under hood of late-1980s B-body wagons, as nearly every one of those got the 307 Olds. Same thing for Caddy Fleetwoods through 1990. Don't forget the early 1980s Eldo, Riviera, and Toro.
Old Feb 18, 2013 | 09:52 AM
thank you. ya the bracket is cheaply made, but the kid should hav been applied that much pressure either. thank you for your help
Old Feb 28, 2013 | 02:28 AM
DeltaPace77's Avatar
Another thing to check, is the alterator itself. As I changed engines a couple times, and the front alternator bracket was rubbing on the alternator cooling fan. Talk about belt squeal, complete with a smoking alternator belt and all. While not the original question, I carry a spare set of V belts and tool kit in the car. Luckily I've never had to use any of this, but loaned the stuff out a couple times.
JuzCallMeDee
Mar 26, 2013 02:25 PM
deltaboy
Feb 6, 2013 01:01 PM
kplange
Jan 7, 2012 07:11 PM
hunter
Nov 18, 2011 11:45 AM
JBrooks
May 27, 2010 02:59 AM
