Broken fuel line
#41
Jim if remember correctly the ac compressor does not run that close to the area i belive they sit close to the valve cover. Ah yeas the steel line barb is my fault should have been steel line , barb fittings,. My fault on that one. That little comma always throws ya off dont it ? I wanna see if i can find a product call a steel line barb. That proves how you pick my post apart becasue most people would probably see it for what it was worth but now you are on a war path and any little thing you can use you use. It's like an argument with my fiance anything she can use she will try to . Also fwiw he could get a better fit notice how i used a 45 degree elbow at the pump .
BTW, your fuel set up would NOT pass TECH at our track. Also, clean job on the trans cooling lines. Nice!
#42
I have line up on the carb and behind the pump feed line. It passes tech at both local tracks. gets the job done. The trans lines are the originals routed out of heats way. they look close to teh headers but stay cool enough. I never said my stuff was fancy it gets the job done and it has for many years with out flaw. Now im finally decided to get a little fancy. It might look ugly but it has ran faster than guys who have spent much more than me so win win for this guy. I dont have alot of extra money to spend., so cheap and functional is the key here. I work on high end cars all day for snobby customers so i know how to do things down to a tee but i have more fun this way and kind of throwing that whole olds is more expensive thing out the window.
#48
Wow, first we had 50+ posts on how to fill a empty cooling system, now 40+ posts on replacing a fuel line, what's next?, 50 or so posts on how to change out an air filter?...........It's amusing to say the least.........
#49
I can be an argumentative PITA, but I will continue to dispute bad advice. Installing a rubber fuel hose on a stock 307 is a bad idea, nobody can claim otherwise considering the stock steel line is available for $20. If my "arguing" keeps somebody from having an under hood fire, then it is worth it. IMHO.
#51
http://s149.photobucket.com/user/cap...ml?sort=3&o=17
Is that rubber fuel line I see in jims car that's for sale ? I wonder if he has had fire yet. Can you say troll. and he has ac. and zip ties
#53
I guess it's do as I say not as I do. I guess he did a bad job on his own car per his standards of what he said. I find this ironic among other things I would call it hypocritical.
#54
#55
You can continue to try and make me look stupid, but it isn't going to work. I am much smarter than you and have many more years experience. That is a 3/8" steel line, I would NEVER run a rubber hose, much less attach it to a steel bracket. Oops, remove foot friom big, fat mouth..........................
#56
#57
Really jim because I see a hose clamp there. attached to the carburetor feed line. Also last I remember those fuel filters like the one you have have barbs on the end. regardless you used rubber hose .I think you should practice what you preach. Im wating for that carb fire. You can call me a hack and whatever you want but I have had no issue with my stuff . For someone against rubber fuel line I think I should see none under there.
This make no sense because you did run rubber hose to the feed line. Here is what also does not make sense. If you made those fuel lines out of 3/8 steel line then whoul wouldn't you try to route is much tighter . You call me a hack yet you use one of the elcheapo dual feedlines and rubber lines give me crap and say how it's unsafe and could cause an underhood fire. for someone who used that as argument I think its hypocritical . Im just worried one of those hose clamps can come loose and you might have an engine fire or maybe even the hose can crack and split .Insert sarcasm here. You can have all the experience you want jim that's not my point . My point is you are a troll you should practice what you preach I know I do and im honest about it and share pics even if I kow other people will give me greif but guess what it's real first hand experience. I don't tell people to no use rubber fuel line then use it for " connection purposes" on my car.
#58
I bought a cheap flare kit from NAPA years ago. The fuel line in the pic below took me 20 minutes to bend, flare and install before work one day last week. It's cheap and easy. In tight areas like this I use a piece of tie wire to mock up the bends required. It gets you close enough almost every time.
#59
You camm me a "troll" then purposely make posts knowing that you will continue a thread was was dead? You started it now, I have a LOT of time and will be reading every post you make quite thoroughly.........
#60
So you are telling me your carb and fuel pump move so you cannot do a solid line. Wow. I understand tank to pump feed line but pump to carb having movement. I never heard that one. I also wil say my line ain't going anywhere been running the same hoses for years no issue.
#61
You are so fvcking ignorant that it is scary. Yes, the ENGINE (fuel pump does bolt to the engine) moves on the motor mounts as it torques up in relation to the fuel line which is fixed on the frame. Have you EVER seen a car with a SOLID fuel line running from the line to the pump?
Keep talking dipsh1t, the hole keeps getting deeper.
#62
#63
What. I'm talking about your rubber splices from your fuel pump to carb here. That's what I been talking about the whole time. I did say. Carb feed line earlier. So what's your excuse on not making that line solid. You are obviously not reading that carefully. Because I explaine the tank to pump being flexible and that's understandable. But why does you pump to carb need rubber. Seems like you hacked it . I never said anything about your tank to pump line I can't even see it.
#64
I know the engine will flex on the mounts but I'm talking specifically pump to carb nothing else. It seems you are trying so hard to avoid why you hacked you lines with unsafe rubber hoses. In you attempts you fail. You wnet on about how unsafe rubber was etc etc. Now I call you out on your own car and sections are fine just like the op could have used a small section to fix his leak . I'm done here.You obviously have shown your true colors . If you where fine with small sections then a small section to fix a leak would be fine with you since you are fine with small sections. This whole thing here was about rubber lines not being safe even for a repair. You are just trying to prove you weren't arguing for the sake of arguing now that I called you out. Kinda pathetic.
#65
#66
No I don't get offended but you obviously had something to prove by name calling. I won't copy and paste the post you edited. Again just like you gave me crap because it seemed like I suggested something when in reality I didn't. I did the same you have done on many of my past post's. Kinda ticks ya off right when people do that right.
Del70
November 15th, 2013 02:24 PM
stlbluesbrother
March 21st, 2011 03:24 PM
