best carb for 69 350-Please help
I asked this before with no answer! can anyone tell me what would be the stock # for a rochester quad for a 1969 350 using a edelbrock intake #3711.
I have read other post that say the rochester is the better carb to use, so I want to know what # carb I should be looking for in a 1969 with a 350
Thanks.
Thanks.
Hi Troy
You could use one of many different quadrajets, although the numbers matching one for your 1969 350 would be 7029250. Since your using an aftermarket intake I don't think the factory choke would work. If it has a place for the hot air tube to go into the intake, you might want to look for an early 70's carb. I went to Brothers Automotive and found their list of Oldsmobile carbs and applications. Some examples would be: 7040250 is 1970, 7041250 is 1971, 7042250 is 1972 and each year used a 251, 252, 253 etc. for different applications. If your intake doesn't have a hot air tube you might have to consider an electric choke. I believe you can get them aftermarket to fit a Quadrajet but am not positive.
Q-jet for the street and strip. I also agree that the Elec. choke is a great way to go for ease of hook-up and driveability. Once you locate a carb, post details of your combo and we can give you some hints on correct calibration .
1968CutlassSupreme
February 8th, 2014 07:06 AM
kandelino
December 20th, 2010 12:54 PM
