best carb for 69 350-Please help
Old Apr 20, 2007 | 05:40 AM
troys2222's Avatar
I asked this before with no answer! can anyone tell me what would be the stock # for a rochester quad for a 1969 350 using a edelbrock intake #3711.
I have read other post that say the rochester is the better carb to use, so I want to know what # carb I should be looking for in a 1969 with a 350
Thanks.
Old Apr 21, 2007 | 07:17 PM
2blu442's Avatar
Hi Troy
You could use one of many different quadrajets, although the numbers matching one for your 1969 350 would be 7029250. Since your using an aftermarket intake I don't think the factory choke would work. If it has a place for the hot air tube to go into the intake, you might want to look for an early 70's carb. I went to Brothers Automotive and found their list of Oldsmobile carbs and applications. Some examples would be: 7040250 is 1970, 7041250 is 1971, 7042250 is 1972 and each year used a 251, 252, 253 etc. for different applications. If your intake doesn't have a hot air tube you might have to consider an electric choke. I believe you can get them aftermarket to fit a Quadrajet but am not positive.
Old Apr 21, 2007 | 09:22 PM
88 coupe's Avatar
Junior Member
Originally Posted by 2blu442
........ If it has a place for the hot air tube to go into the intake ........
It does.
Norm
Old Apr 25, 2007 | 11:38 AM
Edveen's Avatar
As long as your choke is not divorced, you can easily convert the choke to electric! They are a dime a dozen at a salvage yard. I say stick with a rochester. It should be better for street use.
Ed
Old Apr 25, 2007 | 12:49 PM
70Wcars's Avatar
Q-jet for the street and strip. I also agree that the Elec. choke is a great way to go for ease of hook-up and driveability. Once you locate a carb, post details of your combo and we can give you some hints on correct calibration .
1968CutlassSupreme
Feb 8, 2014 07:06 AM
aquabird
Oct 2, 2013 10:34 PM
kandelino
Dec 20, 2010 12:54 PM
1973olds98
Jul 11, 2009 11:47 PM
drtdobber
Feb 14, 2007 01:16 PM
