Any preferred gasket?
Old May 11th, 2009, 09:47 AM
csouth's Avatar
I need to replace the drivers side head gasket on my 350. Is there any brand you guys can recommend that seal better than others or is there any I should definitely stay away from? BTW, would it be recommended that I change both should I have the resources?
csouth is offline
Old May 11th, 2009, 12:59 PM
I use Fel-Pro. Never had problems with them.
Are you changing the gasket because of an overheat? If you are, you'd best be doing the other side too. There may be damage that just hasn't made itself noticed yet. And while you're at it check your thermostat and coolant. Might be the time to change out rad hoses that may have become weak during an overheat too.
The best guy I can think of to give you a real tech answer on this would be Joe Padaveno on this site. I'm sure there's issues with taking the heads off, checking them and the block for warpage, and reinstalling the head correctly with the proper torque and bolt tightening sequence. Sounds like you may have a big job ahead of you. Know a good mechanic who works for beer? Wish I could be more helpful, I only do these things myself when it's easy, or there's no other way around it cause lots of time I don't have right now and space is always an issue.
Allan R is offline
Old May 11th, 2009, 01:44 PM
csouth's Avatar
No, I'm actually replacing because the guy that had it before me took the head bolts loose and I'm wondering if this one is having trouble resealing? I think he thought the had to remove the heads to install new lifters. I dropped the oil before I started the car There was water there, nut not like it ran hot. I just thought about putting a fresh one on.
BTW, will the intake manifold gasket need replacing also? Its the turkey pan style....
csouth is offline
Old May 11th, 2009, 03:15 PM
FelPro blue
joe_padavano is online now
Old May 11th, 2009, 06:06 PM
csouth's Avatar
Joe,
Since the headgasket was never "blown" do you think I whould replace it or try to let the car run and have it reseal?
csouth is offline
Old May 11th, 2009, 07:01 PM
Joe,
Every time I have tried cutting corners, I end up spending even more time and money. Yes, you will need to replace the intake gasket as well.
Old May 11th, 2009, 08:02 PM
csouth's Avatar
Thanks Joe, I'll trust your judgement and just replace it. Should I do both sides?
csouth is offline
Old May 12th, 2009, 04:49 AM
Congratulations. You are well on your way down the slippery slope of MIGHTASWELL...
The one reason to replace both sides would be the difference in compressed thickness of the old gasket and the new ones. In the real world this probably wouldn't be a noticeable difference, but still...
Of course, if both heads are off, you MIGHTASWELL have the valves done.
Old May 12th, 2009, 06:30 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
And you MIGHTASWELL have the heads milled 30 thou, so you don't have 7.5:1 compression.
J-(Chicago) is offline
Old May 12th, 2009, 06:55 AM
csouth's Avatar
It wouldn't be such a dilema if the heads were off... I'm gonna replace the drivers side and let it roll for now. I was hoping to start saving for a rebuild next summer. Just saw an ad for a part car, guy asking 200 for the whole car. Hope its still available. Supposed to have 455, 400 shortail and posi. Wasn't looking for a bb, but at that price....
csouth is offline
Old May 12th, 2009, 08:11 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I really would replace both head gaskets. We could take you way down the mightaswell highway like mightaswell replace the cam and on and on. I would say to you mightaswell replace both head gaskets and put it back together. Just my opinion but for sure what I would do under the circumstances. The rebuild next summer has a way of turning into the following summer and them the other head gasket blows and then you are back into the engine. You would not be happy camper them. Good luck with it.
redoldsman is online now
Old May 12th, 2009, 08:19 AM
csouth's Avatar
The head gasket itself was never blown. They guy that had the car before me removed the inner head bolts on one side. I was going to replace the one because I was wondering if the there would be a problem with it sealing again.
csouth is offline
1968CutlassSupreme
February 5th, 2014 05:45 PM
internationalflagemblem
July 8th, 2013 10:59 PM
chacemastaflex
January 8th, 2013 08:42 PM
Paladin31
Cars Wanted
27
November 30th, 2012 06:07 AM
69442murph
June 6th, 2012 09:38 AM
Quick Reply: Any preferred gasket?
