alinimum intake VS cast intake. wich is better?
Old December 21st, 2012, 09:35 PM
Wildcard's Avatar
i curently have the stock cast intake on my 307 but i am thinking about going to a alinimum intake to shed some weight. is it worth it?
Wildcard is offline
Old December 21st, 2012, 10:23 PM
69350rocket's Avatar
Not with a 307....IMO
69350rocket is offline
Old December 21st, 2012, 10:49 PM
Don't change the intake just to save weight. You should only be concerned about that if you are racing your Olds.
Olds64 is offline
Old December 22nd, 2012, 01:19 AM
Hot Rod Has Been
krooser's Avatar
Don't waste your $$$ unless you are going for more compression and a bigger cam... IMHO of course.
krooser is offline
Old December 22nd, 2012, 06:11 PM
Wildcard's Avatar
thats what i figured. just had to ask. im gonna go with a RV cam in the verry near future.
Wildcard is offline
Old December 22nd, 2012, 06:30 PM
Hot Rod Has Been
krooser's Avatar
That would be a good start...
krooser is offline
Old December 22nd, 2012, 06:50 PM
Octania's Avatar
What kind of 307 has an iron intake?
When you remove intake to change cam, might as well opt for the appropriate A4 or A5 intake at that time, or your favorite aftermarket unit.
Octania is offline
Old December 23rd, 2012, 12:33 AM
DoubleV's Avatar
I don't know the exact detailes, but some ( most? ) B and E bodys had iron intakes. Every G body that I've ever seen had the aluminum one though. I guess they figured the weight savings wasn't worth it in the bigger cars since they were already tanks!
DoubleV is offline
Old December 23rd, 2012, 11:34 AM
The VIN Y motor in my 84 Custom Cruiser has a #14 iron intake.
joe_padavano is offline
Old December 24th, 2012, 08:52 PM
Wildcard's Avatar
just went out and wrote down the motor block number and the vin number off my 83 cutlass supreme 2dr. the intake is iron. i checked it with a magnet.the block number is 3161 GM 5.0L and the vin number is 1GAM47Y90M427502
Wildcard is offline
Old December 24th, 2012, 08:56 PM
Chevy budget Olds powered
coppercutlass's Avatar
I have an o.e. aluminum intake on the 307 that is currently in my 72 . That will be for sale as soon as it's back in the garage for the new 355. if anyone is intrested pm me.
coppercutlass is offline
Old December 24th, 2012, 08:58 PM
Wildcard's Avatar
what would you want for the intake coppercutlass?
Wildcard is offline
Old December 24th, 2012, 09:03 PM
50 bucks . It has the typical corrosion around the water ports but i reoplaced the gasket and i had no issues i can build up the coreners where it is corroded and re shape if for no cost but you migth have to wait a few months before it is available. maybe sooner but right now i got my 77 cutlass and my fiances k5 blazer both in the garage . if i get the rear end done maybe mid febuary.
Old December 24th, 2012, 09:07 PM
Wildcard's Avatar
ok. im hopin to come across a olds 350 soon and rebuild it but if you manage to get it out sooner, let me know.
Wildcard is offline
Old December 24th, 2012, 09:14 PM
I also have a few of those but they are not cores.
Old December 24th, 2012, 09:20 PM
Wildcard's Avatar
and would be expensave as hell to ship to i bet.lol. id be happy to find a olds 350 or a 403 block with a crank.
Wildcard is offline
Old December 25th, 2012, 12:23 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I owned 3 early 307's, all were iron intakes. I bought a used A4 from the USA, not looking for a needle in a haystack. We never had 307's in the 80's Cutlass up here, except the Hust/Olds, 442 and 88 model year. Only aluminum intakes I have seen up here, were on a 84 Hurst/Olds and later swirl port motors. That included a 87 chebby caprice, factory Olds 307 powered.
olds 307 and 403 is offline
Old December 25th, 2012, 03:01 PM
Hot Rod Has Been
krooser's Avatar
Where do you live? keep checking on CL... lots of olds stuff appears on a regular basis.
krooser is offline
Old December 25th, 2012, 04:41 PM
Octania's Avatar
I meant factory installs
that's a 1972 casting, pre-EGR
The chance of it being factory installed on a 1984 is zero.
"just went out and wrote down the motor block number and the vin number off my 83 cutlass supreme 2dr. the intake is iron. i checked it with a magnet.the block number is 3161 GM 5.0L and the vin number is 1GAM47Y90M427502"
I take it that is the ubiquitous #16 casting then, or perhaps #17- large ID typically in the depression aft of the front water crossover... Will have an EGR valve.
Octania is offline
Old December 25th, 2012, 07:39 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
I have had many 307 motors and all have had iron intakes. The only aluminum ones were a5.
I have seen an aluminum a4 before, but in my opinion they are far less common.
I forget the casting number for the irons, because I usually just scrap them.... but I believe it's the same intake as the 403 motors.
Just like a #16. I just recently gave one to Milan so he could flow it. Try PMing him for the details.
J-(Chicago) is offline
Old December 26th, 2012, 07:48 AM
Pretty sure they were the #17 intakes. They were sure heavy and on most 307's up here.
Activate
June 10th, 2013 10:32 PM
craftsmen22
January 11th, 2012 02:32 PM
Mattia-SS
June 19th, 2011 02:10 PM
craftsmen22
March 6th, 2009 05:30 PM
442 Guatemala
October 21st, 2008 11:22 PM
Quick Reply: alinimum intake VS cast intake. wich is better?
