alinimum intake VS cast intake. wich is better?
Old Dec 21, 2012 | 09:35 PM
Wildcard's Avatar
i curently have the stock cast intake on my 307 but i am thinking about going to a alinimum intake to shed some weight. is it worth it?
Old Dec 21, 2012 | 10:23 PM
69350rocket's Avatar
Not with a 307....IMO
Old Dec 21, 2012 | 10:49 PM
Don't change the intake just to save weight. You should only be concerned about that if you are racing your Olds.
Old Dec 22, 2012 | 01:19 AM
krooser's Avatar
Hot Rod Has Been
Don't waste your $$$ unless you are going for more compression and a bigger cam... IMHO of course.
Old Dec 22, 2012 | 06:11 PM
Wildcard's Avatar
thats what i figured. just had to ask. im gonna go with a RV cam in the verry near future.
Old Dec 22, 2012 | 06:30 PM
krooser's Avatar
Hot Rod Has Been
That would be a good start...
Old Dec 22, 2012 | 06:50 PM
Octania's Avatar
What kind of 307 has an iron intake?
When you remove intake to change cam, might as well opt for the appropriate A4 or A5 intake at that time, or your favorite aftermarket unit.
Old Dec 23, 2012 | 12:33 AM
DoubleV's Avatar
I don't know the exact detailes, but some ( most? ) B and E bodys had iron intakes. Every G body that I've ever seen had the aluminum one though. I guess they figured the weight savings wasn't worth it in the bigger cars since they were already tanks!
Old Dec 23, 2012 | 11:34 AM
The VIN Y motor in my 84 Custom Cruiser has a #14 iron intake.
Old Dec 24, 2012 | 08:52 PM
Wildcard's Avatar
just went out and wrote down the motor block number and the vin number off my 83 cutlass supreme 2dr. the intake is iron. i checked it with a magnet.the block number is 3161 GM 5.0L and the vin number is 1GAM47Y90M427502
Old Dec 24, 2012 | 08:56 PM
coppercutlass's Avatar
Chevy budget Olds powered
I have an o.e. aluminum intake on the 307 that is currently in my 72 . That will be for sale as soon as it's back in the garage for the new 355. if anyone is intrested pm me.
Old Dec 24, 2012 | 08:58 PM
Wildcard's Avatar
what would you want for the intake coppercutlass?
Old Dec 24, 2012 | 09:03 PM
50 bucks . It has the typical corrosion around the water ports but i reoplaced the gasket and i had no issues i can build up the coreners where it is corroded and re shape if for no cost but you migth have to wait a few months before it is available. maybe sooner but right now i got my 77 cutlass and my fiances k5 blazer both in the garage . if i get the rear end done maybe mid febuary.
Old Dec 24, 2012 | 09:07 PM
Wildcard's Avatar
ok. im hopin to come across a olds 350 soon and rebuild it but if you manage to get it out sooner, let me know.
Old Dec 24, 2012 | 09:14 PM
I also have a few of those but they are not cores.
Old Dec 24, 2012 | 09:20 PM
Wildcard's Avatar
and would be expensave as hell to ship to i bet.lol. id be happy to find a olds 350 or a 403 block with a crank.
Old Dec 25, 2012 | 12:23 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I owned 3 early 307's, all were iron intakes. I bought a used A4 from the USA, not looking for a needle in a haystack. We never had 307's in the 80's Cutlass up here, except the Hust/Olds, 442 and 88 model year. Only aluminum intakes I have seen up here, were on a 84 Hurst/Olds and later swirl port motors. That included a 87 chebby caprice, factory Olds 307 powered.
Old Dec 25, 2012 | 03:01 PM
krooser's Avatar
Hot Rod Has Been
Where do you live? keep checking on CL... lots of olds stuff appears on a regular basis.
Old Dec 25, 2012 | 04:41 PM
Octania's Avatar
I meant factory installs
that's a 1972 casting, pre-EGR
The chance of it being factory installed on a 1984 is zero.
"just went out and wrote down the motor block number and the vin number off my 83 cutlass supreme 2dr. the intake is iron. i checked it with a magnet.the block number is 3161 GM 5.0L and the vin number is 1GAM47Y90M427502"
I take it that is the ubiquitous #16 casting then, or perhaps #17- large ID typically in the depression aft of the front water crossover... Will have an EGR valve.
Old Dec 25, 2012 | 07:39 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I have had many 307 motors and all have had iron intakes. The only aluminum ones were a5.
I have seen an aluminum a4 before, but in my opinion they are far less common.
I forget the casting number for the irons, because I usually just scrap them.... but I believe it's the same intake as the 403 motors.
Just like a #16. I just recently gave one to Milan so he could flow it. Try PMing him for the details.
Old Dec 26, 2012 | 07:48 AM
Pretty sure they were the #17 intakes. They were sure heavy and on most 307's up here.
Activate
Jun 10, 2013 10:32 PM
craftsmen22
Jan 11, 2012 02:32 PM
Mattia-SS
Jun 19, 2011 02:10 PM
craftsmen22
Mar 6, 2009 05:30 PM
442 Guatemala
Oct 21, 2008 11:22 PM
