79 350 Olds Best Heads for Performance Potential
Old Apr 23, 2022 | 09:16 PM
RealChris's Avatar
Just trying to make my caddy a bit quicker on the road. It's got the olds 350 in it and I'm looking at putting more power to the heads. Luckily for me, I've got olds engines from the early 70s up till the mid-'80s that I could pull parts off. For now, I am looking at heads. Which heads would provide the most potential for power (for the cheapest cost/effort).
-Chris
Old Apr 23, 2022 | 10:15 PM
The 1972- earlier heads have smaller combustion chambers than the 1973-up heads. The exhaust flow better as well.
Old Apr 24, 2022 | 06:14 AM
brownbomber77's Avatar
65-67 2, 3, and 4 heads will have the smallest chambers. You’ll have to drill the head bolt holes out to 17/32 on any of the 65-72 heads. #3 and early 4 will need to have the pushrod holes drilled out with a tapered drill bit (Harbor Frieght ones work well enough) due to the different lifter angle and the pushrod sometimes will hit the guide hole. Also, factory gaskets are .017”, replacement gaskets are .042”. Cut the heads .025” to make up the difference so you’re not losing chamber volume from the increased gasket thickness.
Old Apr 24, 2022 | 06:39 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Without swapping the peanut cam, adding heads that will gain you .5 to 1 compression won't do much. Your 3A heads are crappy and crack prone, so it does make sense to use earlier heads if doing any porting or machine work. Consider dual exhaust to add some power. Is your Cadillac a factory analog fuel injection?
Jan 22, 2022 12:29 PM
69bowtie
Mar 27, 2019 04:48 PM
theoldsrocket
Jun 1, 2011 04:58 PM
flamez
Mar 22, 2010 01:57 PM
80_cutlass
Feb 16, 2010 10:33 AM
