750cfm double pumper on an olds 350 ?
well i have decided to just rebuild my olds 350 and th350 trans instead of going with the 455
and i found this add on craigslist for an offenhauser intake and holley 750cfm double pumper carb
http://sfbay.craigslist.org/eby/pts/564193119.html
my old setup on the cutlass was stock intake and an edelbrock 600 cfm carb and it worked great
but i was wondering if this offenhauser and holley setup would be better ?
or would it be to much for my engine ?
im rebuilding the motor back to stock and im getting the rebuild kit from engine performance warehouse thru my schools machine shop
im going to upgrade the cam to a stage 2 comp or crane cam i cant remember which company it was and get a heavy duty timing chain instead of the standard and probably bore it out .30 over
any advice would be much appreciated
Well, the Offy intake will definitely be lighter. depending what your goals with the motor are, a 750 dub might be overkill. I'd only get it if the price is right. Will you be performing the machine work yourself?
The reason I asked is because most cheapo cast replacement pistons are destroked. I just tore one apart and the pistons were .045 down in the hole. So, if you go that route chances are your final compression ratio will be quite low.
Hypereutectic is a cast piston, with silicon added to the aluminum. It's a good choice. Your Shop Teacher will help you choose the best dish and pin height, for your application.
Your Edelbrock carb will work fine with the Offenhauser manifold. Maybe you can sell the Holley for a few bucks.
Norm
Norm
I used a formula which I found in an old Hot Rod magazine to determine the correct size carb. I found it again when I googled carburetor formula. It was in a site called mortec.com. In my opinion, a 750 double pumper would be to much. I would think something in the 600-650 range would work best. I also thought that dbl pumpers were more for 4spd street/strip use, but that is only what I have read and not experienced. I ran a 650 holley on my 396 and couldn't tell the difference when I installed a 750 holley. Also, I have had several people try to sell me a dbl pumper that was actually dual feed so beware.
Rhett
Rhett
For this application, 500 CFM will be enough.
http://www.4secondsflat.com/Carb_CFM_Calculator.html
Norm
Norm
Last edited by 88 coupe; February 7th, 2008 at 08:52 PM. Reason: Spelling correction
umm the guy agreed to take 80 bucks for the manifold
but
on the summit website it says that none of the offenhauser manifolds will clear and hei cap which i have converted my distributor too so now i dont know what to do
has anyone ever tried using an hei distributor with the offenhauser intake ?
but
if it says it wont clear it, it wont unfortinately, that was the deciding factor for me to get a performer rpm. However if you still have your old distributor you could always go back to that, otherwise grab yourself an edelbrock performer rpm. i say performer rpm, because the performer has been rumored to not be much improvement over a stock 4barrel intake. i found mine used on ebay for 130 bucks. its only like 3 months old. and its in perfect shape
jeremiah did you feel like you lost much low end power when you put the performer rpm on?
im just wondering because it says it doesnt start producing power till 1500 rpm.
I did a comparison between the RPM and Performer on my 355 with a 210/..477 cam in it. The car was a tenth quicker with the Performer and had noticably better off idle throttle response. IMO, 9 to 1 is about the cut off point, more than that I would use the RPM, lress the Performer. Just MHO.
umm stock the olds 350 i have is 10.25 to 1 and i was gonna see if i could go for close to 11 to 1 and going .30 over to get the 355 displacement
and i found out since i work for kragen the normal cost is like 240 in store and if i give my self 30% off i can get a new one for like 190 bucks new so im gonna get the performer rpm
the teacher in the machine shop like 2 months ago was going over rebuild kits with me and he was looking thru 2 catalogs one from engine performance warehouse and the other from someother company
and he crossed everything over i cant remember the cc for the piston but it was in the 60's and he said the compression ration was 10.25 to 1
To be fair, when most of those 10+ engines were offered, 100+ octane was available at the pumps. In some places, 89 is it. My hat's off to the guy who can run an 11 to 1 iron-headed engine on today's fuels that runs good and doesn't detonate. I have yet to talk to a cam grinder (these include Engle, Bullet, and DM) or a builder (these include FRC, DM, RR, and Smitty) who recommend going over 9.8 on a street engine. Yes, it can be done, but your tune (including the cam, timing curve, and A/F) better be dead nuts on.
well i'll see what the machine shop teacher says im going to have him help me with the parts list so everything works together good from carb to crank
and it was only a hope of mine to squeeze more power out of it by increasing the comprestion ratio no one told me it would be a good or bad idea
i'll let you guys know sometime this week or next what im going with
Good move. He is in a position to know more, about your needs/goals, than anyone on the internet.
Whether it's a good, or a bad idea, depends on the rest of your combination. At your power level, you wouldn't see much difference between 9.5 and 10.25 anyway.
Norm
Norm
Here is a link to the announcement: https://classicoldsmobile.com/forums...html#post19257
And here is the evaluation: http://72.22.90.30/phpBB2/viewtopic.php?t=33633.
Not scientific, is an understatement.
Static compression ratio has little, if anything, to do with intake manifold selection.
Good choice. The RPM will make it look more like a real Racecar.
Norm
Norm
Typical Norm post, insulting, how unusual. Yes, my "test" was unscientific, as stated, but a lot more than most guys have done before disparaging the Performer. I am not going to make 2 runs at the track, change intakes, then make 2 more runs for comparisons sake. I will state that my car is noticeably more responsive with the Performer and still runs as good or better ET.
"Static compression ratio has little, if anything, to do with intake manifold selection."
This statement is ridiculous. Cr is crucial in the selection of a cam, which then affects intake manifold choice.
"Good choice. The RPM will make it look more like a real Racecar."
This is you, being a jerk.
Shak. You might consider purchasing the Offenhauser intake and running a points style distributor with a Pertronix conversion kit in it. I ran a Pertronix kit on my 64 Olds 98. It was easy to put in, reasonably priced, and performed superbly. Of course, you probably won't see a difference in 1/4 mi. times when switching from points to HEI / variable reluctor ignition; however, at a mild street engine power level that doesn't matter. I highly suggest the Pertronix kit.
Typical captjim post, childish, how unusual.
As you stated in another thread, but not in this one. Hence, the links, and the comment.
You made no attempt to control/account for, any of the numerous variables. How could that make your comparison any more valid than "most guys"?
Nothing to do with anything. If you did, it would not (due to those "variables") be any more "scientific" than your last "comparison".
It is your car. As long as you are happy with it, that is all that matters.
Which choice might be best for Shaks engine, has nothing to do with how happy you are with your unique application. By recommending one, or the other, you have done him (and everyone else) a disservice.
This statement is childish.
Crucial? No. A major factor? Yes. How major, depends on the application.
OK. Cam choice can affect manifold choice. However, it is only one of many considerations.
This is you, being an adolescent.
Norm
Norm
"Which choice might be best for Shaks engine, has nothing to do with how happy you are with your unique application. By recommending one, or the other, you have done him (and everyone else) a disservice."
Now I am really confused. I thought the purpose of message boards like this is to share experiences and info. So, telling another member with a similar combo to mine that the Performer outperformed the RPM on my 355 is a disservice? I can't agree with that.
"This is you, being an adolescent."
Why is it that you can insult a member in nearly every post you make, but when someone calls you on it, they are immature? Your "Good choice. The RPM will make it look more like a real Racecar" statement was meant to be insulting and demeaning, there is no other purpose to say that.
Hey admins, PM me at ROP or OP and I'll share e-mails and PMs from guys who no longer come here or post here because of Norm. If you wonder why this site (which has a really great bunch of guys for the most part) doesn't get as much traffic as the other Olds sites, Norm is one of the primary reasons. His insulting, arrogant, and bullying posting style keeps other guys from joining in on the conversation. When a guy says "being polite gets in the way of effective communication" that says all you really need to know. I'll leave now and quit cluttering up this site. Obviously, I am one of the few that will call him on his crap, so we end up arguing, and that's no good for anyone. See ya.
i read all of norms last post and none of it was about my thread lol
and olds64 im just going to stick with the HEI i have now, its wired into my msd box and i dont really wanna tinker with the wiring anymore then moving the msd box to where the ac box once was
#31
Everyone:
I've seen it happen on those other two sites. He gets frustrated when someone questions any of his statements. You can see the result.
You said it, I didn't.
And to discuss those experiences and that information. It is always helpful, if the experiences are relevant, and the information is accurate.
I don't belive he will be using 22cc "dished" pistons and an "RV" cam. If he does, we can call them "similar".
Yes. As I explained in post #27, your "comparison" was not valid. Your "improvements" could very well be caused by the placebo effect. Either way, you have no accurate information to pass on to anyone.
Let us put this one into its proper context, shall we?
Looks like a legitimate response, to me.
If anyone disagrees, my PM box is always open.
Why is it that you can find an insult in nearly every post I make? Why is it that when I challenge you to find, define, and post one in a PM, you are unable to do so? Here it is again:
Should be easy enough.
I do not know that anyone has "called me" on anything. I am fully capable of discussing anything I post.
You are mistaken. The CO search engine says, I have only used the word "immature" once, on this site. Here it is, again:
Doesn't look like an insult to me.
I think we can see why you get into so many pizzing contests at those "other" sites.
We can also see, that you were unable to answer the simple (and on topic) questions I asked. Once we have seen through your "smokescreen" that is.
Norm
If you wish to question/discuss the technical content of anything I post, do so. That is the purpose of message/discussion boards, such as this one.
If you wish to discuss my posting style, find the "offending" statement and "post the quote" in a PM, along with your objection to it.
If you are not prepared for a mature discussion, do not waste my time.
Norm
#33
" Why is it that you can find an insult in nearly every post I make? Why is it that when I challenge you to find, define, and post one in a PM, you are unable to do so?"
is not so accurate, as "J" has found the same insult that I did.
#35
There is a loop hole in the system, since anyone can perceive the posts however they choose. I chose to be amused, and it worked out well for me.
I could have also chose to be pissed off and concerned for your feelings, and it also would have interchanged just fine.
Damned if you do, damned if you don't. You 2 should just have a beer and call it a day. All of these comments have been a borderline waste of time and internet space for the admin and aspiring Olds scholars. I'm also pretty sure Shak would like his thread back some time in the near future![Embarrassment](https://classicoldsmobile.com/forums/images/smilies/redface.gif)
Shak, any word on what your shop teacher had to say?
#36
My vote is for the Performer RPM.
My only personal experience with the Performer, was putting one on a stock 85 307. It didn't help any as far as I was concerned, and I personally I feel the car ran slightly worse. That information doesn't really help you out since yours is a 350, and I didn't dyno it. (a why bother situation)
I have a Performer Rpm on my 71 350. My machine shop also felt that It was a better intake to use, but then again, my build and application is probably totally different than yours.
#37
Guest
Posts: n/a
I can't help you with your intake issues, but the rest of you need to not distract the purpose of his thread and see who can **** farther. He wants help not fifteen posts of garbage in his thread.
If you do something like that to one of my threads when I need help...
I'll do absolutely nothing about it.
4door!cutlass
March 25th, 2014 02:23 PM
j_link
December 27th, 2011 10:34 AM
