750cfm double pumper on an olds 350 ?
Old Feb 6, 2008 | 11:40 AM
shaks 442 clone's Avatar
well i have decided to just rebuild my olds 350 and th350 trans instead of going with the 455
and i found this add on craigslist for an offenhauser intake and holley 750cfm double pumper carb
http://sfbay.craigslist.org/eby/pts/564193119.html
my old setup on the cutlass was stock intake and an edelbrock 600 cfm carb and it worked great
but i was wondering if this offenhauser and holley setup would be better ?
or would it be to much for my engine ?
im rebuilding the motor back to stock and im getting the rebuild kit from engine performance warehouse thru my schools machine shop
im going to upgrade the cam to a stage 2 comp or crane cam i cant remember which company it was and get a heavy duty timing chain instead of the standard and probably bore it out .30 over
any advice would be much appreciated
Old Feb 6, 2008 | 01:04 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Well, the Offy intake will definitely be lighter. depending what your goals with the motor are, a 750 dub might be overkill. I'd only get it if the price is right. Will you be performing the machine work yourself?
Old Feb 6, 2008 | 01:39 PM
captjim's Avatar
I doubt that you will be happy with a DP on a daily driver. You are better off with a stock intake or Performer, and a vac secondary carb, be it Q-jet, Holley, or E-brock. BTW, what pistons are you going to use?
Old Feb 6, 2008 | 02:34 PM
either cast or hyperutechtic pistion not sure if thats how its spelled
and the guy only wants 175 for manifold and carb i could probably get them both for 150
Old Feb 6, 2008 | 04:46 PM
captjim's Avatar
The reason I asked is because most cheapo cast replacement pistons are destroked. I just tore one apart and the pistons were .045 down in the hole. So, if you go that route chances are your final compression ratio will be quite low.
Old Feb 6, 2008 | 04:53 PM
Tell him to keep the carb and offer 60 bones for the mani. Worst they can say is go to hell, and no big loss if they do.
Old Feb 6, 2008 | 09:50 PM
88 coupe's Avatar
Junior Member
Originally Posted by shaks 442 clone
either cast or hypereutectic ........
Hypereutectic is a cast piston, with silicon added to the aluminum. It's a good choice. Your Shop Teacher will help you choose the best dish and pin height, for your application.
Your Edelbrock carb will work fine with the Offenhauser manifold. Maybe you can sell the Holley for a few bucks.
Norm
Old Feb 7, 2008 | 05:17 PM
awningman67's Avatar
I used a formula which I found in an old Hot Rod magazine to determine the correct size carb. I found it again when I googled carburetor formula. It was in a site called mortec.com. In my opinion, a 750 double pumper would be to much. I would think something in the 600-650 range would work best. I also thought that dbl pumpers were more for 4spd street/strip use, but that is only what I have read and not experienced. I ran a 650 holley on my 396 and couldn't tell the difference when I installed a 750 holley. Also, I have had several people try to sell me a dbl pumper that was actually dual feed so beware.
Rhett
Old Feb 7, 2008 | 08:48 PM
88 coupe's Avatar
Junior Member
Originally Posted by awningman67
I used a formula ........
For this application, 500 CFM will be enough.
http://www.4secondsflat.com/Carb_CFM_Calculator.html
Norm
Old Feb 7, 2008 | 10:13 PM
umm the guy agreed to take 80 bucks for the manifold
but
on the summit website it says that none of the offenhauser manifolds will clear and hei cap which i have converted my distributor too so now i dont know what to do
has anyone ever tried using an hei distributor with the offenhauser intake ?
Old Feb 8, 2008 | 12:23 PM
The_Jeremiah's Avatar
if it says it wont clear it, it wont unfortinately, that was the deciding factor for me to get a performer rpm. However if you still have your old distributor you could always go back to that, otherwise grab yourself an edelbrock performer rpm. i say performer rpm, because the performer has been rumored to not be much improvement over a stock 4barrel intake. i found mine used on ebay for 130 bucks. its only like 3 months old. and its in perfect shape
Old Feb 8, 2008 | 10:33 PM
jeremiah did you feel like you lost much low end power when you put the performer rpm on?
im just wondering because it says it doesnt start producing power till 1500 rpm.
Old Feb 9, 2008 | 03:11 AM
88 coupe's Avatar
Junior Member
........ it says it doesnt start producing power till 1500 rpm.
Not what it means. Ignore it.
I don't think anyone knows what application those numbers apply to.
Norm
Old Feb 9, 2008 | 05:33 AM
captjim's Avatar
I did a comparison between the RPM and Performer on my 355 with a 210/..477 cam in it. The car was a tenth quicker with the Performer and had noticably better off idle throttle response. IMO, 9 to 1 is about the cut off point, more than that I would use the RPM, lress the Performer. Just MHO.
Old Feb 9, 2008 | 11:21 PM
umm stock the olds 350 i have is 10.25 to 1 and i was gonna see if i could go for close to 11 to 1 and going .30 over to get the 355 displacement
and i found out since i work for kragen the normal cost is like 240 in store and if i give my self 30% off i can get a new one for like 190 bucks new so im gonna get the performer rpm
Old Feb 10, 2008 | 11:55 AM
Oldsguy's Avatar
Past Administrator
10.25:1 stock? what year engine are you talking about? I don't think it would be a 350. I think maybe the 400 was 10.25:1 in '68.
Old Feb 10, 2008 | 01:49 PM
captjim's Avatar
I am not certain but I thought that they did make a high comp 350 back then? Had a smaller dish?
shaks, you are not planning to run this on pump gas, are you?
Old Feb 10, 2008 | 07:56 PM
11-1 compression would be a gamble on the chitty gas around here.
Old Feb 10, 2008 | 08:08 PM
the teacher in the machine shop like 2 months ago was going over rebuild kits with me and he was looking thru 2 catalogs one from engine performance warehouse and the other from someother company
and he crossed everything over i cant remember the cc for the piston but it was in the 60's and he said the compression ration was 10.25 to 1
Old Feb 11, 2008 | 02:30 AM
88 coupe's Avatar
Junior Member
10+ static compression ratios date back to '57. Not a problem to run them on pump gas.
Norm
Old Feb 11, 2008 | 05:20 PM
captjim's Avatar
To be fair, when most of those 10+ engines were offered, 100+ octane was available at the pumps. In some places, 89 is it. My hat's off to the guy who can run an 11 to 1 iron-headed engine on today's fuels that runs good and doesn't detonate. I have yet to talk to a cam grinder (these include Engle, Bullet, and DM) or a builder (these include FRC, DM, RR, and Smitty) who recommend going over 9.8 on a street engine. Yes, it can be done, but your tune (including the cam, timing curve, and A/F) better be dead nuts on.
Old Feb 11, 2008 | 10:28 PM
well i'll see what the machine shop teacher says im going to have him help me with the parts list so everything works together good from carb to crank
and it was only a hope of mine to squeeze more power out of it by increasing the comprestion ratio no one told me it would be a good or bad idea
i'll let you guys know sometime this week or next what im going with
Old Feb 11, 2008 | 10:47 PM
88 coupe's Avatar
Junior Member
well i'll see what the machine shop teacher says ........
Good move. He is in a position to know more, about your needs/goals, than anyone on the internet.
........ no one told me it would be a good or bad idea ........
Whether it's a good, or a bad idea, depends on the rest of your combination. At your power level, you wouldn't see much difference between 9.5 and 10.25 anyway.
Norm
Old Feb 12, 2008 | 03:40 AM
88 coupe's Avatar
Junior Member
Here is a link to the announcement: https://classicoldsmobile.com/forums...html#post19257
And here is the evaluation: http://72.22.90.30/phpBB2/viewtopic.php?t=33633.
Not scientific, is an understatement.
........ IMO, 9 to 1 is about the cut off point ........
Static compression ratio has little, if anything, to do with intake manifold selection.
........ more than that I would use the RPM, less the Performer ........
Good choice. The RPM will make it look more like a real Racecar.
Norm
Old Feb 12, 2008 | 11:44 AM
captjim's Avatar
Typical Norm post, insulting, how unusual. Yes, my "test" was unscientific, as stated, but a lot more than most guys have done before disparaging the Performer. I am not going to make 2 runs at the track, change intakes, then make 2 more runs for comparisons sake. I will state that my car is noticeably more responsive with the Performer and still runs as good or better ET.
"Static compression ratio has little, if anything, to do with intake manifold selection."
This statement is ridiculous. Cr is crucial in the selection of a cam, which then affects intake manifold choice.
"Good choice. The RPM will make it look more like a real Racecar."
This is you, being a jerk.
Old Feb 12, 2008 | 03:36 PM
Shak. You might consider purchasing the Offenhauser intake and running a points style distributor with a Pertronix conversion kit in it. I ran a Pertronix kit on my 64 Olds 98. It was easy to put in, reasonably priced, and performed superbly. Of course, you probably won't see a difference in 1/4 mi. times when switching from points to HEI / variable reluctor ignition; however, at a mild street engine power level that doesn't matter. I highly suggest the Pertronix kit.
Old Feb 15, 2008 | 01:24 AM
88 coupe's Avatar
Junior Member
Typical Norm post, insulting, how unusual ........
Typical captjim post, childish, how unusual.
........ Yes, my test was unscientific, as stated ........
As you stated in another thread, but not in this one. Hence, the links, and the comment.
........ a lot more than most guys have done before disparaging the Performer ........
You made no attempt to control/account for, any of the numerous variables. How could that make your comparison any more valid than "most guys"?
........ I am not going to make 2 runs at the track, change intakes, then make 2 more runs for comparisons sake ........
Nothing to do with anything. If you did, it would not (due to those "variables") be any more "scientific" than your last "comparison".
........ I will state that my car is ........
It is your car. As long as you are happy with it, that is all that matters.
Which choice might be best for Shaks engine, has nothing to do with how happy you are with your unique application. By recommending one, or the other, you have done him (and everyone else) a disservice.
........ This statement is ridiculous ........
This statement is childish.
Originally Posted by 88 coupe
........ Static compression ratio has little, if anything, to do with intake manifold selection ........
........ Cr is crucial in the selection of a cam ........
Crucial? No. A major factor? Yes. How major, depends on the application.
........which then affects intake manifold choice ........
OK. Cam choice can affect manifold choice. However, it is only one of many considerations.
........ This is you, being a jerk ........
This is you, being an adolescent.
Norm
Old Feb 15, 2008 | 08:19 AM
captjim's Avatar
"Which choice might be best for Shaks engine, has nothing to do with how happy you are with your unique application. By recommending one, or the other, you have done him (and everyone else) a disservice."
Now I am really confused. I thought the purpose of message boards like this is to share experiences and info. So, telling another member with a similar combo to mine that the Performer outperformed the RPM on my 355 is a disservice? I can't agree with that.
"This is you, being an adolescent."
Why is it that you can insult a member in nearly every post you make, but when someone calls you on it, they are immature? Your "Good choice. The RPM will make it look more like a real Racecar" statement was meant to be insulting and demeaning, there is no other purpose to say that.
Hey admins, PM me at ROP or OP and I'll share e-mails and PMs from guys who no longer come here or post here because of Norm. If you wonder why this site (which has a really great bunch of guys for the most part) doesn't get as much traffic as the other Olds sites, Norm is one of the primary reasons. His insulting, arrogant, and bullying posting style keeps other guys from joining in on the conversation. When a guy says "being polite gets in the way of effective communication" that says all you really need to know. I'll leave now and quit cluttering up this site. Obviously, I am one of the few that will call him on his crap, so we end up arguing, and that's no good for anyone. See ya.
Old Feb 15, 2008 | 08:37 AM
Stop the madness Norm.
Old Feb 15, 2008 | 09:33 AM
i read all of norms last post and none of it was about my thread lol
and olds64 im just going to stick with the HEI i have now, its wired into my msd box and i dont really wanna tinker with the wiring anymore then moving the msd box to where the ac box once was
Old Feb 16, 2008 | 02:27 AM
  #31
88 coupe's Avatar
Junior Member
Everyone:
I've seen it happen on those other two sites. He gets frustrated when someone questions any of his statements. You can see the result.
........ Now I am really confused ........
You said it, I didn't.
........ purpose of message boards like this is to share experiences and info ........
And to discuss those experiences and that information. It is always helpful, if the experiences are relevant, and the information is accurate.
........ So, telling another member with a similar combo to mine ........
I don't belive he will be using 22cc "dished" pistons and an "RV" cam. If he does, we can call them "similar".
........ that the Performer outperformed the RPM on my 355 is a disservice? ........
Yes. As I explained in post #27, your "comparison" was not valid. Your "improvements" could very well be caused by the placebo effect. Either way, you have no accurate information to pass on to anyone.
........ This is you, being an adolescent.
Let us put this one into its proper context, shall we?
Looks like a legitimate response, to me.
If anyone disagrees, my PM box is always open.
........Why is it that you can insult a member in nearly every post you make ........
Why is it that you can find an insult in nearly every post I make? Why is it that when I challenge you to find, define, and post one in a PM, you are unable to do so? Here it is again:
If you wish to question/discuss the technical content of anything I post, do so. That is the purpose of message/discussion boards, such as this one.
If you wish to discuss my posting style, find the "offending" statement and "post the quote" in a PM, along with your objection to it.
If you are not prepared for a mature discussion, do not waste my time.
Should be easy enough.
........ but when someone calls you on it ........
I do not know that anyone has "called me" on anything. I am fully capable of discussing anything I post.
........ they are immature? ........
You are mistaken. The CO search engine says, I have only used the word "immature" once, on this site. Here it is, again:
It's refreshing to get a mature reply, instead of a personal attack/flame ........
Doesn't look like an insult to me.
........ was meant to be insulting and demeaning, there is no other purpose to say that ........
I think we can see why you get into so many pizzing contests at those "other" sites.
We can also see, that you were unable to answer the simple (and on topic) questions I asked. Once we have seen through your "smokescreen" that is.
Norm
Old Feb 16, 2008 | 08:45 AM
  #32
I thought the race car comment was funny. Not nice, or relevant, but there WAS a very small degree of entertainment value there, thus making it not entirely useless.
Old Feb 16, 2008 | 12:19 PM
  #33
captjim's Avatar
Interesting post. You recognize that Norms comment was not nice, funny, and irrelevant. Hmm. So, a comment that was not nice but funny, could that be an attempt to make fun of another member? And, could making fun of somebody be considered an insult? I think so. So, there you have it Norm, independent corroboration from J-(Chicago) He recognizes that your remark was clearly meant as an insult, as does everybody else. So this statement;
" Why is it that you can find an insult in nearly every post I make? Why is it that when I challenge you to find, define, and post one in a PM, you are unable to do so?"
is not so accurate, as "J" has found the same insult that I did.
Old Feb 16, 2008 | 12:50 PM
  #34
cmon guys lets get back on topic
should i get the performer series intake or performer rpm
help!!!
Old Feb 16, 2008 | 01:02 PM
  #35
There is a loop hole in the system, since anyone can perceive the posts however they choose. I chose to be amused, and it worked out well for me.
I could have also chose to be pissed off and concerned for your feelings, and it also would have interchanged just fine.
Damned if you do, damned if you don't. You 2 should just have a beer and call it a day. All of these comments have been a borderline waste of time and internet space for the admin and aspiring Olds scholars. I'm also pretty sure Shak would like his thread back some time in the near future
Shak, any word on what your shop teacher had to say?
Old Feb 16, 2008 | 01:14 PM
  #36
My vote is for the Performer RPM.
My only personal experience with the Performer, was putting one on a stock 85 307. It didn't help any as far as I was concerned, and I personally I feel the car ran slightly worse. That information doesn't really help you out since yours is a 350, and I didn't dyno it. (a why bother situation)
I have a Performer Rpm on my 71 350. My machine shop also felt that It was a better intake to use, but then again, my build and application is probably totally different than yours.
Old Feb 16, 2008 | 01:23 PM
  #37
dar83501
Guest
Posts: n/a
I can't help you with your intake issues, but the rest of you need to not distract the purpose of his thread and see who can **** farther. He wants help not fifteen posts of garbage in his thread.
If you do something like that to one of my threads when I need help...
I'll do absolutely nothing about it.
Old Feb 16, 2008 | 04:53 PM
  #38
monday is presidents day and i wont have access to the shop till wednesday so i'll probably be letting you guys know wednesday
Old Feb 17, 2008 | 04:50 AM
  #39
88 coupe's Avatar
Junior Member
........ anyone can perceive the posts however they choose. I chose to be amused, and it worked out well for me ........
Thank you.
Norm
Old Feb 17, 2008 | 04:55 AM
  #40
88 coupe's Avatar
Junior Member
........ but then again, my build and application is probably totally different than yours.
And thank you, again.
Norm
4door!cutlass
Mar 25, 2014 02:23 PM
HonestDave
Jan 5, 2013 03:34 PM
j_link
Dec 27, 2011 10:34 AM
Gearhead442
Jan 7, 2010 07:23 AM
