64 olds cutlass f85 body mounts
Yup.....Lube, let soak, pray, apply impact wrench. If you are lucky the impact shocks them loose. Did I mention pray
I took all my bolts loose and jack up one side replaced all the mounts and put bolts back in loose. Jack up the other side and replaced all the mounts. Made sure all was straight and went around and tighten all. You know there are 7 per side. All have bolts. Also plus two on the rad support. All my bolt came out perfect.
Gene
Gene
joesw31
May 31st, 2015 04:17 PM
