64 olds cutlass f85 body mounts
Old Dec 4, 2008 | 06:51 PM
lou tecco's Avatar
how hard is it to change the body mounts on my 64 olds cutlass
can it be done on a lift
i have the new ones to install
with new bolts
Old Dec 4, 2008 | 07:49 PM
The problem isn't replacement of the mounts, it's the collateral damage that happens when you spin one of the cage nuts and have to cut a hole in the floor pan to get to it.
Old Dec 4, 2008 | 08:59 PM
gearheads78's Avatar
car guy
Yup.....Lube, let soak, pray, apply impact wrench. If you are lucky the impact shocks them loose. Did I mention pray
Old Dec 9, 2008 | 05:01 PM
64Rocket's Avatar
I took all my bolts loose and jack up one side replaced all the mounts and put bolts back in loose. Jack up the other side and replaced all the mounts. Made sure all was straight and went around and tighten all. You know there are 7 per side. All have bolts. Also plus two on the rad support. All my bolt came out perfect.
Gene
Old Jun 16, 2011 | 06:49 PM
lou tecco's Avatar
Can you take oil pan off 64 olds cutlass without pulling motor
Old Jun 18, 2011 | 11:22 AM
64Rocket's Avatar
Man this is an old thread.
Yes you can. You have to jack up the engine so high, drop the pan to clear the flywheel. Be careful of the fan shroud and the distributor.
Gene
Old Jun 20, 2011 | 05:59 PM
lou tecco's Avatar
i have jetaway trans no fan shroud non air car
have hei dist
joesw31
May 31, 2015 04:17 PM
deltathunder
Aug 11, 2014 06:11 AM
Nasty455
Mar 20, 2012 04:57 PM
flatoz
Mar 15, 2009 02:03 PM
riverrat
Body work
Mar 11, 2009 09:43 PM
