455 heads on 350?
Old October 28th, 2007, 11:34 AM
Pghstarsky's Avatar
455 heads on 350?
Will 455 heads fit directly onto a 350 block? I dont think they will but I overheard someone talking about how it would work. Thanks
Pghstarsky is offline
Old October 28th, 2007, 03:11 PM
falconsfan's Avatar
ive read some threads stating you can but it changes the compression ratio if youre using stock 350 pistons?
Maybe someone with "the know" will post as I have a chance to pickup some 455 heads for my 350 and would like to know the answer as well.
falconsfan is offline
Old October 28th, 2007, 06:47 PM
captjim's Avatar
They physically bolt on, but will seriously lower the CR over the older 350 heads. And you can get the same size valves in a SBO head. Also, you will have intake issues, I believe you will need to port match an RPM, but not positive about that.
captjim is offline
Old October 29th, 2007, 08:50 AM
Yes, all Olds heads are the same size and bolt pattern. 77-up small blocks use 1/2" head bolts vs. 7/16" on 76-older blocks. You can drill early heads for the larger bolts.
As others have noted, big block heads have 80cc chambers vs. 64-ish chambers on 70-earlier SBO heads. The BBO heads also have larger ports that a street-driven 350 will be hard-pressed to use. The Performer RPM and some factory intakes are the only ones with enough meat to port-match to the BBO ports. Failing to do this matching will negate any flow benefits. As others have noted, simply maching the SBO heads for the big block valves is a much cheaper way out (and is what the factory did on the W-31).
joe_padavano is offline
Old October 29th, 2007, 11:28 AM
Pghstarsky's Avatar
Interesting, thank you so much for your prompt response.
64 CUTLASS KEN
December 7th, 2020 06:43 AM
lunaboy
September 24th, 2018 10:15 AM
ut442
March 9th, 2012 11:57 AM
69OLDSCUTCONV
November 18th, 2011 06:53 PM
DarkStar
October 21st, 2009 07:35 AM
Quick Reply: 455 heads on 350?
