403 popped a freeze plug is it okay
Old Jan 15, 2026 | 02:00 PM
Flashflood's Avatar
My 403 in 77 lemans popped a freeze plug while it was sitting over by my mechanic shop. Literally this car is literally close to going to the dark side, as it sat over at mechanic not getting worked on for 6 months. The freeze plug is up front but I don't know how good the rest of them are. I haven't even heard this thing run. Feeling depressed!!!
Old Jan 15, 2026 | 02:32 PM
Is it because the block froze or just old age? And yes, others could be suspect.
Old Jan 15, 2026 | 03:01 PM
Flashflood's Avatar
I guessing the block froze as we've had freezing temps. Also i did put water in it at first cause i was going to break it in June. Okay thanks do you know the locations of the other plugs?
Old Jan 15, 2026 | 04:52 PM
BillK's Avatar
Three down each side.
Old Jan 15, 2026 | 04:55 PM
Flashflood's Avatar
Are they all the same size? Can they be done with the motor in the car
Old Jan 15, 2026 | 06:45 PM
2blu442's Avatar
Here's a 350 block. Your 403 would have freeze plugs in the same locations and yes they are the same size. I've never replaced them on an engine in the car, but it would at least be tight as the exhaust manifold goes over them.
Old Jan 16, 2026 | 05:31 AM
I bet that the engine would at least have to be lifted to replace those freeze plugs. Hopefully someone will chime in that knows for sure.
Apparently it can be done with cussin' & fussin'
https://classicoldsmobile.com/forums...ug-fun-177848/
Old Jan 16, 2026 | 06:18 AM
Sugar Bear's Avatar
An expandable rubber frost plug could be used temporarily to test run the engine to see if it was damaged. In addition to the freeze risk, sitting without coolant will allow major corrosion. Try to keep at least 30% coolant in the system.
Old Jan 16, 2026 | 09:48 AM
Charlie Jones's Avatar
Phantom Phixer
Check the block carefully for cracks.
If it froze hard enough to pop a freeze plug, It may well have cracked the block.
Find another mechanic shop.
Old Jan 16, 2026 | 05:35 PM
The motor mounts will prevent access to the two center freeze plugs. The starter will be in the way of the rear driver side plug. The exhaust manifolds will also be a problem.
Old Jan 16, 2026 | 06:48 PM
Flashflood's Avatar
I'll pop the manifold off and pop a rubber one in there for the time being. I've got a full set on order so... I'll keep you guys posted if anything I'll losen the motor and see about tipping the motor up.
Old Jan 17, 2026 | 05:43 PM
Flashflood's Avatar
So I put a temp one in there what is optimal break in weather. This is freshly rebuilt motor that's the only reason I'm asking. Any other things I should be worried about.
Old Jan 17, 2026 | 07:32 PM
I would make sure the antifreeze is good to future protect from freezing again.
Old Jan 17, 2026 | 08:13 PM
Flashflood's Avatar
will do I'll go through some coolant in there tomorrow.
Old Feb 17, 2026 | 07:22 AM
Toocool's Avatar
Dont forget the freeze plugs in the heads.
Old Apr 19, 2026 | 08:02 PM
Flashflood's Avatar
whelp this absolutely sucks as I was replacing the temp freeze plug it went to the block and is stuck in it. Leaving me with an inoperable engine and a big giant mess of coolant.
Old Apr 20, 2026 | 04:56 AM
fleming442's Avatar
Mechaniking is hard. It's not going to go anywhere. Try again.
Old Apr 20, 2026 | 05:50 AM
Sugar Bear's Avatar
If the temporary plug fell into the block and you cannot get it out, don't worry about it, leave it there and install another one. Will it help anything sitting in there? No. Will it hurt anything? VERY unlikely. It will be fine.
mike 66 toro
Mar 25, 2024 06:46 PM
Donaldbabineau
Aug 21, 2021 06:34 AM
KW5413
Sep 17, 2020 12:37 PM
ds00469
Jan 25, 2014 05:12 PM
davebw31
May 22, 2013 01:51 PM
