403 motor mounts
Old March 30th, 2009, 06:20 AM
oldsowner1977's Avatar
403 motor mounts
Hey everyone i have a Delta 88 pace car replica. im having a small problem i have done a motor swap from a 350 olds to a 403 olds. the only thing is i can find any motor mounts that will seem to work everyone hands me the same mount and it just doesnt line up. anyone got any ideas?
Thanks ,AJ
oldsowner1977 is offline
Old March 30th, 2009, 06:58 AM
Thanks ,AJ
The Olds 350 and 403 are externally identical, including the motor mount bolt holes. Your correct mount should be Anchor P/N 2328:
What exactly doesn't line up?
joe_padavano is offline
Old March 30th, 2009, 11:05 AM
the wholes to the frame. i guess my dad found them finaly at car quest.
Old March 30th, 2009, 11:56 AM
I guess I'm still confused. Are you talking about the metal frame brackets to the crossmember or the rubber mount I posted above to the frame brackets? The crossmember should have all the holes for all the possible available engines (Olds, Buick, Chevy, Pontiac, and Caddy). If someone had improperly installed the frame brackets, that would cause a misalignment, however if the car previously had a 350 Olds, the frame brackets would have already been in the correct place.
Old March 30th, 2009, 12:26 PM
the rubber mount to the frame
Old March 30th, 2009, 03:45 PM
Often you will need to leave the mount-to-block bolts loose until you get the bolt into the frame mount. I've also noticed that the Chinesium Anchor brand mounts have quite a bit of production tolerance on them. One of the mounts I recently purchased had the holes for the block bolts drilled incorrectly. I had to slot the hole with a file to get it bolted to the block.
Old March 30th, 2009, 07:18 PM
well found out why it was being a but. my dad had turned or something to the frame mount. and it was keeping it from linging up.
Old March 31st, 2009, 06:17 AM
now its timing that we have to figure out . crazy thing. i hope it starts in the next cupple days.
naphtali5725
March 1st, 2015 04:42 AM
Nasty455
March 20th, 2012 04:57 PM
78 omega 468
August 21st, 2010 06:54 AM
ctrain22
May 20th, 2009 11:02 PM
flatoz
March 15th, 2009 02:03 PM
Quick Reply: 403 motor mounts
