403 motor mounts
Old Mar 30, 2009 | 06:20 AM
oldsowner1977's Avatar
403 motor mounts
Hey everyone i have a Delta 88 pace car replica. im having a small problem i have done a motor swap from a 350 olds to a 403 olds. the only thing is i can find any motor mounts that will seem to work everyone hands me the same mount and it just doesnt line up. anyone got any ideas?
Thanks ,AJ
Old Mar 30, 2009 | 06:58 AM
Thanks ,AJ
The Olds 350 and 403 are externally identical, including the motor mount bolt holes. Your correct mount should be Anchor P/N 2328:
What exactly doesn't line up?
Old Mar 30, 2009 | 11:05 AM
the wholes to the frame. i guess my dad found them finaly at car quest.
Old Mar 30, 2009 | 11:56 AM
I guess I'm still confused. Are you talking about the metal frame brackets to the crossmember or the rubber mount I posted above to the frame brackets? The crossmember should have all the holes for all the possible available engines (Olds, Buick, Chevy, Pontiac, and Caddy). If someone had improperly installed the frame brackets, that would cause a misalignment, however if the car previously had a 350 Olds, the frame brackets would have already been in the correct place.
Old Mar 30, 2009 | 12:26 PM
the rubber mount to the frame
Old Mar 30, 2009 | 03:45 PM
Often you will need to leave the mount-to-block bolts loose until you get the bolt into the frame mount. I've also noticed that the Chinesium Anchor brand mounts have quite a bit of production tolerance on them. One of the mounts I recently purchased had the holes for the block bolts drilled incorrectly. I had to slot the hole with a file to get it bolted to the block.
Old Mar 30, 2009 | 07:18 PM
well found out why it was being a but. my dad had turned or something to the frame mount. and it was keeping it from linging up.
Old Mar 31, 2009 | 06:17 AM
now its timing that we have to figure out . crazy thing. i hope it starts in the next cupple days.
naphtali5725
Mar 1, 2015 04:42 AM
Nasty455
Mar 20, 2012 04:57 PM
78 omega 468
Aug 21, 2010 06:54 AM
ctrain22
May 20, 2009 11:02 PM
flatoz
Mar 15, 2009 02:03 PM
