371 carb throttle shaft linkage plate ?
Hi
I am in the process of replacing the rochester 2 barrel carb on my 371. The rebuilt carb is identical EXCEPT the throttle linkage plate. Since the engine is not in the original car the carb linkage plate was altered. A tab was welded to the plate for a lower linkage. I am guessing for the trans kickdown. Anyway how do i remove the plate from the rebuilt carb? The one in it has a phillips head screw that threads into the throttle shaft that retains the plate. the rebuild has a std setup, not sure how to describe it, rounded on the ends with a flat surface top and bottom.?. Not sure if this is a screw? Or how it holds the plate to the throttle shaft?. Any help is very much appreciated.
first photo shows current modified carb. Note the phillips head.. that threads into the throttle rod retaining the linkage “plate” on the current engine. (Hooks to the gas pedal and the lower to trans kick down. The second photo shows the std carb. (Pedal connect the same but no kick down connection) Note the odd shaped “retainer” that holds the linkage” plate” to the throttle shaft. Sorry for the wording not sure how to describe it.. i need to swap the linkage “plates” to connect the std carb to the engine
Hi
I think you have two choices:
1. Swap the bottom sections of the carb.
2. Grind the peening off to remove the plate, drilling and tapping the throttle shaft.
3. Cut the fabricated plate off and hope you can get it welded in the proper location and position.
......Just my two cents worth.
Hi
Thank you for the help. I was afraid that the end was peened but wasn't sure. I agree i will switch the bottom sections and that should do the trick.
thanks again saved me a lot of frustration.
Wyocutlass71
September 6th, 2019 07:32 AM
Rocketscienceguy
July 11th, 2017 09:34 PM
1965cutlassragtop
March 18th, 2017 06:59 AM
sqeeek
March 14th, 2017 10:35 AM
CutlassLegend
September 14th, 2011 11:34 AM
