350 Cylinder Heads - Side Specific?
Old December 21st, 2013 | 03:09 PM
tgilligan's Avatar
Hey Guys,
Had the heads recently machined and rebuilt and now I'm bolting them back on the car. Are they side specific or are the driver and passenger side heads interchangeable?
Old December 21st, 2013 | 03:36 PM
2blu442's Avatar
Interchangeable, they are identical castings.
John
Old December 21st, 2013 | 04:37 PM
stan 65 cutlass's Avatar
being 350 i guess no no# on one head
Old December 21st, 2013 | 06:31 PM
Lars's Avatar
Huh???
Old December 22nd, 2013 | 05:37 AM
380 Racer's Avatar
Originally Posted by Lars
Huh???
Yes I was wondering about that too.
Old December 22nd, 2013 | 07:15 AM
Huh???
350s were made from '68 onward, while the engine number was stamped on the front of the right side head from '67 back, so if it's a 350, he doesn't need to consider assembling it so that the head with the engine number is on the right side.
Old December 22nd, 2013 | 09:45 AM
The 1964-67 motors have the engine unit number stamped on the front end of the passenger side head. Often the heads are inadvertently swapped when a valve job is done and this number ends up on the rear of the driver's side head. There are many threads here where this has come up.
Old December 22nd, 2013 | 02:36 PM
380 Racer's Avatar
So if they got switched would the earth open up or just a lightening strike?
Old December 22nd, 2013 | 02:43 PM
No, but that little number stamped into one face of one head is the only conceivable reason why someone might be able to say that the two heads are not identical.
Old December 22nd, 2013 | 02:51 PM
Actually it causes the engine to run backwards.
Old December 22nd, 2013 | 03:05 PM
Lol.
Old December 22nd, 2013 | 03:55 PM
Octania's Avatar
Requiring the use of a Ch*vy distributor of course. And you have to run positive ground so that the starter spins the other way.
j/k of course
Old December 22nd, 2013 | 09:21 PM
380 Racer's Avatar
actually it causes the engine to run backwards.
lol
Old December 23rd, 2013 | 08:12 AM
Actually, it doesn't. I've got a 1952 Allis Chalmers tractor that was originally 6V positive ground. I changed it to 12V negative ground and didn't need to touch the starter. It DOES spin a lot faster now, however...
DQ81
May 30th, 2014 07:12 PM
Big Henry
Body work
May 23rd, 2012 07:29 AM
olds70supreme
August 31st, 2009 02:31 PM
Vyse
Paint
June 21st, 2009 12:25 AM
nonhog
June 2nd, 2009 12:50 PM
Quick Reply: 350 Cylinder Heads - Side Specific?
