350 Cylinder Heads - Side Specific?
Old Dec 21, 2013 | 02:09 PM
tgilligan's Avatar
Hey Guys,
Had the heads recently machined and rebuilt and now I'm bolting them back on the car. Are they side specific or are the driver and passenger side heads interchangeable?
Old Dec 21, 2013 | 02:36 PM
2blu442's Avatar
Interchangeable, they are identical castings.
John
Old Dec 21, 2013 | 03:37 PM
stan 65 cutlass's Avatar
being 350 i guess no no# on one head
Old Dec 21, 2013 | 05:31 PM
Lars's Avatar
Huh???
Old Dec 22, 2013 | 04:37 AM
380 Racer's Avatar
Originally Posted by Lars
Huh???
Yes I was wondering about that too.
Old Dec 22, 2013 | 06:15 AM
Huh???
350s were made from '68 onward, while the engine number was stamped on the front of the right side head from '67 back, so if it's a 350, he doesn't need to consider assembling it so that the head with the engine number is on the right side.
Old Dec 22, 2013 | 08:45 AM
The 1964-67 motors have the engine unit number stamped on the front end of the passenger side head. Often the heads are inadvertently swapped when a valve job is done and this number ends up on the rear of the driver's side head. There are many threads here where this has come up.
Old Dec 22, 2013 | 01:36 PM
380 Racer's Avatar
So if they got switched would the earth open up or just a lightening strike?
Old Dec 22, 2013 | 01:43 PM
No, but that little number stamped into one face of one head is the only conceivable reason why someone might be able to say that the two heads are not identical.
Old Dec 22, 2013 | 01:51 PM
Actually it causes the engine to run backwards.
Old Dec 22, 2013 | 02:05 PM
Lol.
Old Dec 22, 2013 | 02:55 PM
Octania's Avatar
Requiring the use of a Ch*vy distributor of course. And you have to run positive ground so that the starter spins the other way.
j/k of course
Old Dec 22, 2013 | 08:21 PM
380 Racer's Avatar
actually it causes the engine to run backwards.
lol
Old Dec 23, 2013 | 07:12 AM
Actually, it doesn't. I've got a 1952 Allis Chalmers tractor that was originally 6V positive ground. I changed it to 12V negative ground and didn't need to touch the starter. It DOES spin a lot faster now, however...
DQ81
May 30, 2014 06:12 PM
Big Henry
Body work
May 23, 2012 06:29 AM
olds70supreme
Aug 31, 2009 01:31 PM
Vyse
Paint
Jun 20, 2009 11:25 PM
nonhog
Jun 2, 2009 11:50 AM
