330 stock head help!
Old Jan 7, 2011 | 10:40 PM
330noob's Avatar
Does anyone know what the maximum lobe lift on a stock 330 head? i heard that most chevy heads the max is .500
thanks 330noob
Old Jan 8, 2011 | 09:17 AM
Run to Rund's Avatar
Depends on what valve ratainer, valve seal as well as on guide height. The only way to be safe is to check it.
Old Jan 8, 2011 | 03:01 PM
330noob's Avatar
how can i find out? or measure what my maximum is?
Old Jan 8, 2011 | 03:28 PM
InfoJunkie's Avatar
InfoJunkie
.475 lift would be a safe bet.
To figure out your max lift measure your installed height for the valve springs then measure the valve springs fully compressed. Subract the smaller number from the larger number then subtract .080 per coil. That should be your max lift for the springs. When you install a new cam you should also change the springs so that they have the proper pressure for the cam.
young olds
Jun 3, 2014 08:13 PM
odddoylerules
24
Jan 22, 2014 06:35 AM
delta254
Dec 3, 2012 08:37 AM
Mike H.
Jun 7, 2011 07:50 AM
Deltarocket
Jun 5, 2007 06:54 AM
