330 heater hook up
330 heater hook up
I rebuilt my 330 2 years ago and finally I am trying to get it on the road. Switched from 2 to 4 barrel. Can this heater on the choke simply be hooked up to the intake manifold or does it need to go to the exhaust.
As said, someone added an electric choke coil to a carb that originally had a hot air choke coil. So cap off the port and connect the wire to a switched 12 Volt power source. Joe P has a detailed write up on wiring the electric choke that can be found in a simple search.
Tiberian Fiend
August 12th, 2016 01:49 PM
joepenoso
June 12th, 2013 11:05 AM
