330 heater hook up
Old Jun 13, 2020 | 12:41 PM
330jetstar's Avatar
330 heater hook up
I rebuilt my 330 2 years ago and finally I am trying to get it on the road. Switched from 2 to 4 barrel. Can this heater on the choke simply be hooked up to the intake manifold or does it need to go to the exhaust.
Old Jun 13, 2020 | 01:02 PM
Well that looks like an electric choke so connect it to a switched 12 Volt source.
Old Jun 13, 2020 | 02:00 PM
330jetstar's Avatar
Yes, what about the port to the right.
Old Jun 13, 2020 | 02:18 PM
442Harv's Avatar
Looks like someone took the old choke housing and added a electric choke, so that fitting is not needed.
Old Jun 13, 2020 | 02:20 PM
330jetstar's Avatar
Currently the electric choke is not hooked up. Why would both be on the carb?
Old Jun 13, 2020 | 02:27 PM
442Harv's Avatar
I think the car originally was not a electric choke, it was added to the old housing. What part is not hooked up?
Old Jun 13, 2020 | 06:36 PM
As said, someone added an electric choke coil to a carb that originally had a hot air choke coil. So cap off the port and connect the wire to a switched 12 Volt power source. Joe P has a detailed write up on wiring the electric choke that can be found in a simple search.
Tiberian Fiend
Aug 12, 2016 01:49 PM
RustyOlds
Mar 11, 2016 06:03 AM
weasel
Feb 1, 2013 10:15 PM
belairbob
May 12, 2012 04:51 AM
