324 Coolant Leak
Old April 14th, 2012, 06:22 PM
Rocket331's Avatar
Exclamation 324 Coolant Leak
I filled up our newly rebuilt 324 with coolant today. After a while, I discovered coolant dripping from the lower center exhaust manifold bolts.
Anyone else had this happen? What's the best fix?
Rocket331 is offline
Old April 14th, 2012, 10:33 PM
oldsmobum's Avatar
The holes for those bolts run right through to the coolant passages... But I'm not sure the threads do. Make sure your bolt didn't bottom out. I noticed that happened on mine when I did some exhaust work and installed new bolts. Of course check torque... I'm not sure if any of the silicone sealants will hold up to the heat, but I think some of the anti-seize compounds will. Not sure if that will be good to seal the threads, but it might be worth a shot...
oldsmobum is offline
Old April 22nd, 2012, 01:18 PM
Rocket331's Avatar
I put a light coating of high temp RTV on the bolts, put them back in and torqued them to 22 ft-lbs. I let it sit for a couple days, then refilled the coolant. Couple weeks have passed. No leaks! I hope that did the trick.
65topless
May 6th, 2013 06:15 PM
yeahbuddy
April 9th, 2010 03:48 PM
olds88royalvert
September 10th, 2009 05:03 PM
cutlass47
Tech Editor's Desk
October 7th, 2008 06:29 AM
Diabolus
July 23rd, 2004 04:35 AM
Quick Reply: 324 Coolant Leak
