215 v8 Question
Old Mar 6, 2015 | 08:07 PM
jalopyjim's Avatar
215 v8 Question
i have a 61 f85 i would like to make fuel injected . Ive read alot from this site . the 4.6 rover engine catches my interest . I was recently reading about a 5.0l rover engine . what is identical? what can fit ? what cant? is it worth the time?
Old Mar 7, 2015 | 04:52 AM
Welcome. The Rover V8s are externally identical to the BOP 215 motors, so yes they will bolt in. There are many internal differences, including the fact that the later Rover motors don't use a distributor. I've got a 4.6 Rover short block to go into my 62 F-85 wagon. All intake and exhaust ports are the same, so manifolds interchange. Go to britishv8.org for more info.
Old Mar 7, 2015 | 11:43 AM
James A Shaw's Avatar
thank you . ok so will i have to switch timing cover and cam ? also what are my options for fuel injection . the simpler the better . i dont want too many wires. so i was thinking a older model for fuel injection ?
Old Mar 7, 2015 | 12:12 PM
The later Rover motors have the oil pump on the front of the crank, so the cover and pump need to be swapped as a unit. There are too many permutations to list here. Again, go to britishv8.org and you'll find all this info.
As for injection, the simplest is the most expensive - a modern aftermarket self-learning throttle body. You can adapt the Rover unit, but you'll want an aftermarket ECU, not the original one, and thus you'll be building your own harness. If that daunts you, stick to a carb.
Old Mar 8, 2015 | 09:02 AM
rustyroger's Avatar
'87 Delta 88 Royale
British SD1 Rovers had Bosch K-Jetronic fuel injection, a simple and reliable system used by many European makers.
But it is long out of production now, and i don't know if it was used much in North America. Perhaps getting a Range Rover engine complete with wiring harness would be your best bet.
Roger.
Old Mar 8, 2015 | 03:32 PM
Actually, if you just want to put EFI on the 215, there are folks who've adapted GM TBI units for TR8s. You can get the .BIN file with the fuel and spark map on line if you use the stock '7747 ECU and just burn a new PROM. You can still score the parts from a 305 pickup at a wrecking yard for not too much money.
Old Mar 8, 2015 | 10:03 PM
cjsdad's Avatar
Dunno where you are located but here is a 215 Olds with Rover trans on Craigslist in Albuquerque. Doesn't say if it is FI or not.
http://albuquerque.craigslist.org/pts/4915811789.html
1970-W30
Sep 27, 2014 12:20 PM
beachmont
Jul 7, 2012 09:50 AM
sam196370
Apr 2, 2012 02:20 PM
nonhog
Jul 8, 2011 03:03 PM
63 F85 Cutlass
Dec 28, 2008 07:18 PM
