1986 Code '9' 307
Old November 3rd, 2013, 12:29 PM
mmurphy77's Avatar
1986 Code '9' 307
When I bought my '86 442 brand new I remember the Service Manager saying now the HO 307 was a 'roller' motor. I understood 'roller' valvetrain was new in '86 but just read something recently that made me believe '86 was the ONLY year. Did every other year after that get the roller set up too or was it '86 only? Was it only the HO (Vin code '9') engines or all 307s? Hard to believe it would be a one year only offering.
mmurphy77 is offline
Old November 3rd, 2013, 01:48 PM
The "roller" part refers to the lifters only, not the rockers. The roller cam was used on all 1985-1990 VIN Y 307s and all 1986-1987 VIN 9 307s (and presumably later VIN 9 motors as used in Caddy Fleetwoods). By the way, this was not necessarily an upgrade, as the roller cam motors also got the peanut port 7A heads and matching A5 intake.
joe_padavano is offline
Old November 3rd, 2013, 07:08 PM
mmurphy77's Avatar
Thanks Joe. I was not aware it was lifters only. Also I would assume the switch to 7A heads and 5A intake explains why the '86-'87 motors had 10 less horsepower but 10 more lb/ft of torque than the previous version. I wish I'd kept that car.
Old November 4th, 2013, 07:52 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Olds went completely backwards for performance with swirl port. When they introduced the Vin 9 in 83 it was very similar or had more power than other 5.0 HO's. Dropping compression and shrinking ports made it an embarrassment.
olds 307 and 403 is offline
Old November 4th, 2013, 08:31 AM
You can thank the CAFE requirements and the decision to stick with a carb instead of moving to EFI for this.
Old November 4th, 2013, 09:13 AM
Agree completely. Too bad they didn't copy the FEX prototype motor. Shows what decent exhaust and cold air induction will do,.
Old June 25th, 2019, 10:44 AM
kris-sarah's Avatar
code 9
what exactly is meant by vin code 9? is this the code on the motor, or is this the Vin code on the car? and which place in the vin do we look for the number 9?
trying to dissect what my wagon is
thanks for the assist.
Bruce
kris-sarah is offline
Old June 25th, 2019, 11:07 AM
same but different
don71's Avatar
I think its the eighth? digit in the Vehicle Identification Number located on the dash and on the title and probably the insurance paperwork. It refers to roller lifters instead of hydraulic lifters.
don71 is offline
Old June 25th, 2019, 11:18 AM
kris-sarah's Avatar
I just bought an 89 caprice wagon, with an Olds 307. vin 1G1BN81Y9KA----------
by this number, can I determine what trans, rear gear ratio, engine, etc? and if so, how?
thanks
Bruce
Old June 25th, 2019, 12:59 PM
Hoffa65's Avatar
referrers to HO motor (9) vers. non HO motor (Y). roller lifters across both motors in 86
Hoffa65 is offline
Old June 25th, 2019, 01:18 PM
Bruce
The eighth character in your car's VIN is the engine code. For 1986, Olds used two different 307 motors, the "Y" code 140 HP version and the "9" code 180 HP version. Don''t worry about this, your wagon has the VIN Y motor. Only 442s got the VIN 9 motor that year.
Hotlil307
July 11th, 2021 05:53 AM
truckerlary
May 1st, 2015 05:01 PM
gbody 442
April 30th, 2013 10:28 AM
gm guy
August 27th, 2008 11:29 AM
87cutlas
May 28th, 2008 11:14 PM
Quick Reply: 1986 Code '9' 307
