Cam change in a 307
Old Nov 1, 2016 | 09:17 PM
Hotlil307's Avatar
Cam change in a 307
I have a 1986 olds307 vin y with 7a heads roller cam does anybody know if i can but a flat tappet cam in it
Old Nov 1, 2016 | 09:19 PM
Hotlil307's Avatar
307 new cam ?
I have a 1986 olds 307 vin y with 7a heads an roller cam can i switch that cam out with a flat tappet cam cause i want a tad bigger cam
Old Nov 2, 2016 | 03:57 AM
quaddriver's Avatar
4 Barrels of Laughs
From: I moved to pittsburgh so I can be near Primantis
tappet bores are different, so sure, just buy the proper parts.
why tho? unless you are improving the heads and exhaust, aint much a larger cam grind is gonna do that a 350 wont solve by sliding it under the intake....
Old Nov 2, 2016 | 04:11 AM
Why not get a tad bigger roller?
Old Nov 2, 2016 | 05:20 AM
I moved your question to a new thread. When I saw J-Chicago's reply to the old thread I knew it was old. Let us know if you have any more questions.
Old Nov 2, 2016 | 06:29 AM
jcdynamic88's Avatar
i think a tad bigger engine is a better idea
Old Nov 2, 2016 | 05:15 PM
Cutlass Fan's Avatar
What are the specs on your roller cam? You won't be able to put a very big cam in a low comp 307 without seriously hurting drivability. A properly designed roller cam wil perform better over a greater rpm range than a similar flat tappet grind.
Old Nov 2, 2016 | 07:07 PM
Plus with the roller you don't have to worry about what oil to use.
Old Jul 11, 2021 | 05:53 AM
86 Olds 442's Avatar
Replying to old thread, but as you have a roller cam to start, you can use Comp 262. Use 7.700 pushrodd and the Vin 9 springs.Consider a chip to modify your timing curve for the increased duration and lift, but keep your initial timing at 20 deg
72delta88
Oct 25, 2020 12:01 PM
mattking
Nov 13, 2015 11:59 AM
dre
Drivetrain/Differentials
Aug 31, 2011 11:04 AM
