1977 Oldsmobile 350
I may have them if I can break the bolts loose after 30+ years. They're on a 76 455. If someone can verify 76 brackets are the same as 77 I'll start spraying PB Blaster.
Up front they'll need bead blasting.
This is the diagram i found i mainly just need the piece that’s labeled 2
