1975 350 Coolant Change
Old Mar 1, 2025 | 03:12 PM
Tuffnut's Avatar
I would like to do a rad and engine coolant change in my garage.
No issue draining the rad and containing the coolant. I want to drain the engine as well, by removing the block plugs.
Any suggestions on containing the coolant when removing the plugs? I don’t want it all over my floor.
Old Mar 1, 2025 | 03:40 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Big drain pan and do one side at the time.
Old Mar 1, 2025 | 03:44 PM
Sugar Bear's Avatar
Don't open the radiator cap and pull those plugs first. The vacuum with the cap on will slow the drainage.
Old Mar 1, 2025 | 09:58 PM
dragline's Avatar
When refilling you might want to raise the front of the car to allow air to escape out of the system.
klleetrucking
Feb 1, 2019 03:43 PM
dc2x4drvr
Mar 21, 2014 07:20 PM
Seff
Feb 4, 2014 11:37 AM
olds88royalvert
Sep 10, 2009 05:03 PM
