1972 350 rocket
In a perfect engine, at least 4.5 qt should drain out the plug. Another half quart will come out from the filter when it is removed. I often find at least 1/4 of that 1/2 will be running down my arm as I am unscrewing the filter...
Good...I feel better now that this happens to someone else. The other 4 1/2 quarts go just to side of where the pan is to catch the oil....
When putting the oil in, I put in four quarts and wait 15-20 minutes to allow it to drain down, then I pull the dipstick, wipe it, re-insert and pull it again to get an accurate reading. Make sure that you reference the cross hatch area on the dipstick.
