350 rocket 1972 cuttlas problem
Old Sep 22, 2010 | 05:10 PM
mryoung4815's Avatar
Question 350 rocket 1972 cuttlas problem
I have a 72 olds cuttlass s 350 rocket and I lost the power steering belt and the alt belt so I bought new belts so when I took the alt bracket and power steering pump and neg ground bolts I don't rember how they go back I don't have ac at all so is there a diagram I can go by to put it back together properly.?
Old Sep 22, 2010 | 06:51 PM
69oldsguy's Avatar
You really didn't need to take any brackets apart. You only have to loosen the pivot bolts and the slide adjustment bolts.
Anyway, your alternator should be on the passenger side and the P.S. on the drivers side. Is there any way you can post pics of the brackets that you have disassembled? I really have no way of knowing what all you have taken apart without pics.
Old Sep 23, 2010 | 03:01 PM
i just uploaded some picks for you
Old Sep 23, 2010 | 04:11 PM
citcapp's Avatar
No pictures did you go to manage attachments at the bottom of the page after hitting reply at the top of the page then follow the directions
Old Sep 23, 2010 | 04:30 PM
pics
this should do it
Old Sep 23, 2010 | 08:56 PM
70 cutlass s's Avatar
The pic in the middle that bracket bolts to the the lower alt. bracket and to the back of the alt. When you look at the back of the alt. you will see a bolt hole for it.
FYI your bracket and pulley setup is for a car with A/C. Some one most have remove the compressor at some point.
Old Sep 24, 2010 | 01:51 PM
69oldsguy's Avatar
X2. Either it is an A/C car or someone put an A/C motor complete with alternator in.
70 cutlass has you on the right track. You'll get it back together.
oldman72
Aug 25, 2011 09:41 AM
dharlett
Sep 23, 2009 03:30 PM
BigBertha442
Apr 10, 2008 10:10 AM
1972madison
Jul 10, 2007 02:32 PM
