1972 350 rocket
Old Aug 19, 2011 | 02:52 PM
oldman72's Avatar
1972 350 rocket
How much oil should my engine be holding when i change it?
Old Aug 19, 2011 | 02:59 PM
GAOldsman's Avatar
"Car"mudgeon
5 quarts
Old Aug 19, 2011 | 03:41 PM
Lady72nRob71's Avatar
In a perfect engine, at least 4.5 qt should drain out the plug. Another half quart will come out from the filter when it is removed. I often find at least 1/4 of that 1/2 will be running down my arm as I am unscrewing the filter...
Old Aug 19, 2011 | 04:45 PM
cutlassjoe's Avatar
Good...I feel better now that this happens to someone else. The other 4 1/2 quarts go just to side of where the pan is to catch the oil....
Old Aug 25, 2011 | 08:25 AM
hunter's Avatar
When I changed the oil I used 5 qt but you can always go from 4-5 qt's. I feel I put too much in though.
Old Aug 25, 2011 | 08:55 AM
When putting the oil in, I put in four quarts and wait 15-20 minutes to allow it to drain down, then I pull the dipstick, wipe it, re-insert and pull it again to get an accurate reading. Make sure that you reference the cross hatch area on the dipstick.
Old Aug 25, 2011 | 09:41 AM
None, hopefully...
Now, AFTER you change it, there should be five quarts.
mryoung4815
Sep 24, 2010 01:51 PM
dharlett
Sep 23, 2009 03:30 PM
BigBertha442
Apr 10, 2008 10:10 AM
1972madison
Jul 10, 2007 02:32 PM
