1971 Cutlass Vapor Cannister - gas odor
Old Nov 20, 2025 | 07:43 AM
JVCCutlass's Avatar
I have not removed it to inspect yet, but since ts the original one I'm guessing that it might need some attention since I get bad gas odor at times.
Is the inside of this serviceable - that is, can the filter element be replaced ?
I see an entire cannister replacement at some of the parts places, but is there an actual replacable filter element inside ?
Thanks in advance
Joe
Old Nov 20, 2025 | 05:21 PM
2blu442's Avatar
Check out this thread:
​​​​​​Rebuild evap/vapor canister - ClassicOldsmobile.com
Old Nov 20, 2025 | 06:02 PM
70sgeek's Avatar
'72 Cutlass ragtop
I just replaced mine with a Duralast VC-120 canister - it's essentially a GM replacement part from what I can tell, in all respects but for the absence of an actual GM part number. My old one has the replaceable filter pad that comes out from the bottom, but you still have the charcoal matter inside a sealed portion of the canister.
I wasn't ambitious enough to cut mine open for an overhaul so the Duralast unit was the perfect option for me.
Falkon
Apr 15, 2023 07:59 PM
72455
Mar 10, 2023 08:29 PM
70Cutrag
May 23, 2018 05:44 AM
PetChemMan
Aug 8, 2006 08:41 AM
