1966 Cutlass engine belts for 330
Old Oct 2, 2021 | 11:27 AM
35tac's Avatar
In the spring my 66 Cutlass vert with a 330 engine will need new belts. Its a power steering only engine. Two belts accordingly. My assembly manual calls for a power steering belt 382644 with a 59.50 belt length. The alternator belt calls for 382616 with a a length of 49.62. I need a suggestion for replacement belts that have stock outside face look and satisfy the install. No rush just need some excellent selections. Should be no problem to install I would think.
Wayne
Old Oct 2, 2021 | 11:43 AM
rocketraider's Avatar
Oldsdruid
Most you'll find now will be cogged belts which work great, just don't have the look some of us want.
Since you have the specified lengths, visit a NAPA or Federated parts store and see if they have an old fashioned belt length gage. Then see what non-cogged belts they have in the lengths you need. If you're lucky enough to have the old belts you can use that belt gage to match length to what was on it.
I think those belt gage tools are still made. Saw an awfully new looking one in Tractor Supply when I went after a lawnmower drive belt a couple weeks ago.
Old Oct 2, 2021 | 02:03 PM
You may be able to get cog free belts from and industrial bearing/belting supplier in your town. Just bring them in and have them match them up.
Old Oct 3, 2021 | 07:30 AM
I've used vbeltsupply.com with good results.
Old Oct 3, 2021 | 08:06 AM
35tac's Avatar
Thanks Joe!
Wayne
Old Oct 4, 2021 | 03:58 PM
Papa D's Avatar
old67
I am using Gates XL7597 and XL7495 with my 330. cogged belts.
Old Oct 4, 2021 | 04:24 PM
Bfg's Avatar
Bfg
I will definitely look them up, leave it to Joe P. to steer us in the right direction
Old Oct 5, 2021 | 04:25 AM
35tac's Avatar
Gates belts
What is your application? 330, Power steering and alternator?
Wayne
Old Oct 20, 2021 | 03:54 PM
35tac's Avatar
1966 Cutlass belts.
Joe, are the belts used on my application supposed to be 7/16 (.4375) or 1/2 (.500) wide? What is common these days 7/16 or 1/2?
Wayne
Old Oct 20, 2021 | 05:41 PM
Papa D's Avatar
old67
yes. 330 with power steering and alternator
Old Oct 20, 2021 | 05:49 PM
35tac's Avatar
I assume you are saying either / or ?
Wayne
Koda
May 17, 2021 12:10 PM
olds 307 and 403
Oct 10, 2016 07:07 PM
mefirst72
Apr 10, 2014 10:09 AM
Allan R
Feb 20, 2012 08:31 PM
Joeypete
Feb 2, 2010 06:58 PM
